Beginner needs help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-10-2013, 05:13 AM - Thread Starter
Fred1920's Avatar
Hi all,
For my first thread I need your experience in A/V systems.
We are installing a big distribution for a client but we have some issues I explain:
So we have a Samsung UE75ES9080 the input HDMI2 (ARC) is connected to an Atlona PRO3HDREC. This receiver is connected to an Atlona PRO3HD44M HDBase-T matrix. We have a Denon AVR-4520 connected to the first input of the Atlona Matrix and on this Denon we have a Denon DBT-1713UD, a Western Digital TV and a french SAT box.
More simple:
Samsung TV <
PRO3HDREC <
PRO3HD44M <
DENON AVR-4520 <
Device (BR, WDTV,...)
We're using OpenRemote to control our devices and I've some macros to start/stop devices. My actual macro does:
1. Start SAT box
2. Start Samsung TV
3. Start Denon AVR-4520
4. Start Atlona matrix
5. Select input 1 to output 1 on the matrix
The issue is that my TV shows "HDMI 2" and a resolution of 720x480 then the screen goes black as the TV is shutdown but it isn't.
I change the source to WDTV i.e. (same macro but start WDTV in place of SAT) and the sync is OK 1920x1080p no problem. I go back to SAT and it works fine. If I start on source WDTV same thing I've to switch and come back to the source to make it work.
My question is in which order do I have to start the devices to have a good handshake?
I need to know that because this configuration is only for one room, I've other rooms where I've a Gefen 8x8 HDMI matrix where I've some Blu-rays or WDTV connected so it add a layer.
Thanks for your help
Regards
Fred1920 is offline
post #2 of 4 Old 07-16-2013, 03:34 AM - Thread Starter
Fred1920's Avatar
Don't want to flood but.. Someone?
Fred1920 is offline
post #3 of 4 Old 07-16-2013, 04:18 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Sounds more like a remote control question. There is a Remote Control subforum.
I'm not familiar with OpenRemote. I'd use something better supported for a pro install - a platform that offers tech support. You're wasting time (and money) chasing this issue.
Try using a more descriptive thread title. Does OpenRemote use IR, IP, or 232 control? I can't tell if your problem is with OpenRemote, or with IR/IP in general.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 07-17-2013, 01:38 PM - Thread Starter
Fred1920's Avatar
Thanks Neurorad for the reply.
all the commands are sent with global cache gc100 with the ir leds provided by GC.
Fred1920 is offline
Reply Home A/V Distribution
