IPOD - Home Receiver w/speakers and wireless speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-12-2013, 01:46 PM - Thread Starter
BOHLER's Avatar
Hello. Need help. Not too savvy as you'll probably tell by this question.
I have my itunes downloaded on my iphone. I generally plug it into a home stereo receiver with speakers throughout the house. I recenly purchased a wireless speaker that is synced to the ipod. What I'd like to do is have the ipod plugged into the receiver and have music indoors and music outdoors using the wireless speaker. Problem is when I plug the ipod into the receiver - it won't work with the bluetooth to transmit to outside. It seems to be one way or the other - not both. Bummer...any suggestions?
BOHLER is offline
post #2 of 2 Old 07-12-2013, 01:57 PM
Gramin's Avatar
I doubt you can get around that. You want the ability to stream music simultaneously via bluetooth and while plugged in. Not going to happen.
My suggestion... look for a true whole home audio solution. Or at the very least, a wireless solution that allows multiple speaker placements. Sonos would probably be your best bet. Look at their Play 3 and Play 5.
Gramin is offline
Reply Home A/V Distribution
