Using Wireless HDMI instead of doing a HDMI run/drop for new PJ install - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2013, 11:46 AM - Thread Starter
McKinneyMagnum's Avatar
About to install a PJ in my dedicated media room, but when the room was built a HDMI cable was not pre-wired.
So, I can either have the installer do a physical cable run (mabye 30' total) or he mentioned using a wireless HDMI setup. The PJ will be ceiling mounted about 14' from the screen. All my wiring is below the screen for speakers, sat, internet, etc.
Can't seem to find much info on 'wireless HDMI' products. Any suggestions of things that work and will provide the same audio/visual quality as a hard wire?
Bryan
McKinneyMagnum is offline
post #2 of 4 Old 07-16-2013, 12:34 PM
Gramin's Avatar
You're better off doing a new drop. And if you're only going about 30', you might be able to do that yourself. That's actually a very short run that you should be able to accomplish with fish tape. And if you pick up some of the slim Redmere HDMI cables from Monoprice, it will make running the drop even easier.
Gramin is offline
post #3 of 4 Old 07-16-2013, 01:32 PM
Joe Fernand's Avatar
Quoted: 290 Post(s)
Liked: 168
HDMI.org wont sanction any ‘wireless’ HDMI products – look for ‘Wireless HD’ instead! (www.whdi.org being one version)
There are lots of them out there – just be prepared to have a few false starts before you find something which is trouble-free in your installation and don’t assume you won’t have to revert to wires!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #4 of 4 Old 07-16-2013, 02:17 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
If you didn't run HDMI to the projector location - what WAS run? Component video? Any Cat5e? There are HDMI-over- products that will be more reliable than wireless, and may be cheaper than having a wire pulled (assuming you don't have decent access to just run one...)
Jeff
jautor is offline
Reply Home A/V Distribution
