Perfect Vision RG6 Cables - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-01-2013, 01:08 AM - Thread Starter
amanisdude's Avatar
Does anybody use these guys? I've found a QS solid copper RG6 cable by them for nearly half the price of comparable cables with nearly identical specs.
Their products do seem to be used in some short-run patch cables and are sold in spools on eBay, but I don't see much other testimony about the cable's quality.
Is there anyone here with experience with Perfect Vision cables? How do they compare to Belden or other top-grade cables? Links to the datasheets are below in case that helps.
-amanisdude
__________________
Links:
Perfect Vision ULPVRG6SCQUAD Quad-Shield Cable: https://www.perfect-vision.com/webstore/spec-sheets/ULPVRG6SCQUAD.pdf
Belden 7916A Quad-Shield Cable (for comparison): http://www.belden.com/techdatas/english/7916A.pdf
___________________
amanisdude is offline
post #2 of 10 Old 08-01-2013, 04:06 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
ifor is offline
post #3 of 10 Old 08-02-2013, 04:55 AM - Thread Starter
amanisdude's Avatar
Thanks! Somehow this didn't come up in any of my searches.
Unfortunately for me, I've already ordered a *MEAGER* 500 feet of Perfect Vision RG6 cabling, which is already its way. --sigh--
Well, I'll try and take my best care to install it and report my findings back here. Maybe I'll get lucky that it'll get damaged enough en route for them to take it back, although they'd probably just send me another roll.
Alternatively, I suppose I could just make and sell a bunch of short-run cables like these guys are doing, although I'd probably be too embarrassed to do that if the quality is poor.
-amanisdude
__________________
post #4 of 10 Old 08-04-2013, 03:11 AM
acesat's Avatar
Actually I use Perfect Vision Solid Copper RG6 every day on my Directv and Dishnet installs. My only complaints with them is I buy it in 1000' reels that come in boxes, and the boxes always fall apart before I'm done with the roll. You definitely will win brownie points with any tech that comes to your home by having solid copper. cool.gif
amanisdude likes this.
acesat is offline
post #5 of 10 Old 08-04-2013, 02:20 PM - Thread Starter
amanisdude's Avatar
Haha, yeah. I have yet to see an explanation of why those who don't like it think Perfect Vision cables are of poor quality, so I might as well give it a shot.
The only thing I can think of is the outer jacket may not be as durable as other cables, which might present a problem because I have to tug this stuff through walls and insulation. We'll see how it goes. smile.gif
-amanisdude
__________________
post #6 of 10 Old 08-04-2013, 04:02 PM
acesat's Avatar
Not really, the biggest difference I notice between solid copper and copper clad steel is that solid copper is more malleable meaning you have to be slightly more gentle with it around corners because it bends easier. Apart from the shoddy cardboard Perfect Vision is a reputable name in coax.
acesat is offline
post #7 of 10 Old 08-05-2013, 10:57 AM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
This question comes up a lot.
Steel core RG6 is designed for CATV drop cables. These can span 50 feet or more from a pole to a residence so the steel core adds strength. As RF in CATV is within the skin effect area, a copper clad is sufficient for good signal transfer.
DBS has DC power as well as audio band control signals feed back to the dish. Here the copper cladding while ideal for the RF from the dish, is not sufficient for the DC power or low frequency control signals at longer lengths. This is why DBS doesn't recommended copper clad steel RG6. It usually works under 100 feet however.
Copper clad RG6 is not made because it's cheaper. It's made for a specific purpose, that is strength on self supporting runs.
Glimmie is offline
post #8 of 10 Old 08-05-2013, 08:42 PM
acesat's Avatar
They also use a steel messenger wire for support too. Our messenger wire is copper though for grounding, it's not for support. I have no problems putting voltage on CCS but a longer run isn't worth the gamble for me I will use SC.
acesat is offline
post #9 of 10 Old 08-08-2013, 08:12 PM - Thread Starter
amanisdude's Avatar
With regard to the Perfect Vision cable I ordered, it's a ULPVRG6SCQUAD, meaning that it has a solid copper core (not coper clad steel as most other Perfect Vision cables) and is quad shielded. (I checked the cable once I received it, and it does indeed have a solid copper core.)
Furthermore, according to the little information in its spec sheet, its electrical characteristics nearly at par with the Belden 7916A or 7915A, except for its attenuation rating, which is slightly worse.
Also, from what I've seen so far, the cable's jacket seems durable and the cable itself appears to be strong. I'll install it and post here if I have any trouble. Thanks for all the help!
-amanisdude
__________________
post #10 of 10 Old 08-09-2013, 12:03 AM
acesat's Avatar
I somewhat doubt that you would ever be able to perceive any difference between that and any other brand of cable, type of shielding, and center conductor material. Solid copper is rarely if ever at all prewired in homes because it's more expensive and the only real advantage is it doesn't drop voltage as fast. HOWEVER, one thing is for sure, it can handle anything you throw at it. And for people like us it's a very small price to pay for that peace of mind.
acesat is offline
Reply Home A/V Distribution
