Russound SMS Disk Image - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 42 Old 11-11-2015, 05:05 PM
funkyfunky's Avatar
Liked: 0
I have an image of the SMS3 that I could share.... I have changed mine over to an SSD with IDE/SATA converter.
Has anyone had any luck updating the interface?
funkyfunky is offline
post #32 of 42 Old 01-08-2016, 10:19 AM
dleasman's Avatar
looking for SMS3 disc image
Originally Posted by mmancuso13 View Post
Do you still have the image for the SMS3? I need a copy as my disk died. Anyway I can get a copy from you?
I am also in dire need or a disk image for my SMS3.
Is there anyone out there that has one?
-Dana
dleasman is offline
post #33 of 42 Old 10-16-2016, 12:18 AM
sddavid's Avatar
-Dana
Help! I need SMS3 hard disk image as well, hard disk dead and no backup.
sddavid is offline
post #34 of 42 Old 10-17-2016, 10:47 AM
sddavid's Avatar
Originally Posted by mpr5231 View Post
@Duxcub @phili76 I do have the disk image. Sorry I've been away for a while... message me if you're still needing one!
Hi I need am image do you still have one? I can't pm yet so can ay one contact me at sddavidl at hot mail dot com
Thanks in advance!
David
sddavid is offline
post #35 of 42 Old 12-02-2016, 11:05 AM
sddavid's Avatar
I have a working SMS3 160 GB, let me know if you'd like a disk image.
Hi how are you? My Russound SMS3 is dead and I have no backup... Do you still have an image? I'd take whatever size you have cause I'm screwed.
David
sddavid is offline
post #36 of 42 Old 12-20-2016, 06:07 PM
sddavid's Avatar
Originally Posted by Postwise View Post
My SMS3 just died. It no longer boots. I assumed it was a hard drive failure. I have a back-up hard drive image, so I swapped it with the original. Still woouldn't boot. Went to Fry's, bought new memory. Still wouldn't boot. It may be the CPU, but I am done troubleshooting. My wife always hated how difficult it was to build a playlist on the SMS3. I just bought a Mac Mini, going with iTunes now. There are only two of us in the house, we don't need three different audio streams. Now I just have to sort out how to convert the Russound library to iTunes and keep the meta data.<br><br>
Sorry, enough about me. I also have a 160 GB original disk image. If you still need it, I believe I have what you need. Let me know how to contact you, and I can send you the 160 GB hard drive. I used this image to copy to a 500 gig hard drive, and then re-sized the partition with partition magic to take advantage of the larger disk space.<br><br>
What part of the country are you in?
Hey can I get that image?? I have a 160 HD failure on my SMS3 sddavidl at Hotmail dot com
Please!!!
sddavid is offline
post #37 of 42 Old 12-29-2016, 04:09 PM
Postwise's Avatar
Do you still need an image?
Please private message me.
Postwise is offline
post #38 of 42 Old 03-03-2017, 04:25 AM
Liked: 0
It's on an IDE drive. I think I can resize the media portion of the image. So whatever size you can send me should be fine.<br><br>
If you know of a way to do this better, and you are willing to talk me through it, I am happy to try it.<br><br>
jim
Hi Postwise
I also have problem's with a faulty harddrive on my sms3.
Are You still up for helping a russound owner which desperatly need help ?
Regards Heinz
hheinzen is offline
post #39 of 42 Old 03-03-2017, 05:06 PM
Postwise's Avatar
SMS3 Hard Drive
Is there a way I contact you directly?
Postwise is offline
post #40 of 42 Old 03-04-2017, 09:16 AM
Liked: 0
Hi Postwise
Thank You for your quick response.
Of cause: h h e i n z e n 'at sign' h.O.t.M.a.I.l 'period sign' c.O.m
Regards
Heinz
hheinzen is offline
post #41 of 42 Old 09-11-2017, 10:41 PM
KE2D's Avatar
Add me to the club of failed SMS3 drives. 320gb WD AV drive.
Can anyone provide me with an image? I have a few nib 200gb drives, but worse case if need be, I'll just buy a drive to match the image size.
Also, how is everyone restoring the image onto the new drive?
Anyone do a SSD upgrade?
Eric
k2cb at comcast dot net
KE2D is offline
post #42 of 42 Old 10-06-2017, 08:39 AM
KE2D's Avatar
Well meanwhile, I tried to buy a used unit off eBay to get ahold of a good hard drive. eBay unit also arrived with a bad hard drive. I could REALLY use some help in finding a good image or working hard drive.
Thanks for any leads or assistance.
Eric
KE2D is offline
Reply Home A/V Distribution
