Russound SMS Disk Image - AVS Forum | Home Theater Discussions And Reviews
post #1 of 42 Old 08-21-2013, 02:20 PM - Thread Starter
kabdalla's Avatar
I just had my Russound SMS3 hard drive crash and my backup ghost image is corrupted. Anyone on here with an SMS willing to share their disk image? Thanks in advance.
kabdalla is offline
post #2 of 42 Old 08-30-2013, 10:51 PM
Postwise's Avatar
My SMS3 just died. It no longer boots. I assumed it was a hard drive failure. I have a back-up hard drive image, so I swapped it with the original. Still woouldn't boot. Went to Fry's, bought new memory. Still wouldn't boot. It may be the CPU, but I am done troubleshooting. My wife always hated how difficult it was to build a playlist on the SMS3. I just bought a Mac Mini, going with iTunes now. There are only two of us in the house, we don't need three different audio streams. Now I just have to sort out how to convert the Russound library to iTunes and keep the meta data.
Sorry, enough about me. I also have a 160 GB original disk image. If you still need it, I believe I have what you need. Let me know how to contact you, and I can send you the 160 GB hard drive. I used this image to copy to a 500 gig hard drive, and then re-sized the partition with partition magic to take advantage of the larger disk space.
What part of the country are you in?
Postwise is offline
post #3 of 42 Old 08-31-2013, 05:49 PM
bassdoughboy's Avatar
Please I would love to get a copy of the image. I am from South Carolina,USA. Do I need to set up a FTP site or do you have a way of getting it to me.
bassdoughboy is offline
post #4 of 42 Old 09-02-2013, 08:45 AM - Thread Starter
kabdalla's Avatar
@Postwise, thank you for the offer, I'll definitely take you up on it. I'm in Austin, TX and I emailed you to the address you PM'd me. Let me know the best way to coordinate.
kabdalla is offline
post #5 of 42 Old 09-02-2013, 07:36 PM
Postwise's Avatar
Here's what the disk image looks like.
I copied the original drive to a 500 gig drive and resized the media partition to take advantage of the extra space.
If you want to send me a drive and a pre-paid shipping label, I can copy my drive to yours and send it back to you.
jim
Jim Sterling
PO Box 2514
Manhattan Beach, CA 90267
Postwise is offline
post #6 of 42 Old 09-03-2013, 05:58 PM
Will see if I can find a 500 Gig HD if not, can you copy to smaller drive?
post #7 of 42 Old 09-03-2013, 10:41 PM
Postwise's Avatar
I believe I can, I just don't have a way of testing it.
Postwise is offline
post #8 of 42 Old 09-04-2013, 05:13 PM
do you have the image on IDE or on SATA, I read on an earlier post that you have a 160 gig image I know I can find a IDE that would be at least that size. I can send it.
Thanks again
post #9 of 42 Old 09-04-2013, 05:32 PM
Postwise's Avatar
It's on an IDE drive. I think I can resize the media portion of the image. So whatever size you can send me should be fine.
If you know of a way to do this better, and you are willing to talk me through it, I am happy to try it.
jim
Postwise is offline
post #10 of 42 Old 09-07-2013, 12:37 PM
How do you want the drive formated, or leave unformated?
post #11 of 42 Old 09-18-2013, 02:53 PM
postwise
Checking to see how things are going.
Have you had any luck putting the image on them?
post #12 of 42 Old 10-08-2013, 04:08 PM
Thanks for the help Postwise
post #13 of 42 Old 02-09-2014, 06:28 PM
tunes2013's Avatar
Does anyone have the original BIOS settings for the Russound SMS250?
tunes2013 is offline
post #14 of 42 Old 02-11-2014, 01:10 AM
chansuresh's Avatar
I have a working SMS3 with 160gb drive Maxtor Diamond Max. I made a clone myself on to a Western Digital Caviar Blue 320gb and keeping the 160gb as my backup in case of hdd failure. A technician at Russound told me that the SMS3 motherboard only recognizes up to 320gb and so I would not try to use a clone above that. The cloning process was done using Acronis True Image Live CD (don't use from within Windows). Also do not use the option to proportionally size the partitions, but instead did an exact copy. That left a 160gb unallocated sector -- for this I came in again with Gparted and resized the media partition alone to take up the extra HDD space.
While doing the cloning, I made 2 more SMS3 clones onto larger disks and tested them too -- if anyone is interested in them please PM me.
After the switch the SMS3 is working perfectly -- now that it has tested fine, I have proceeded to transfer via network connection all the existing music files in the SMS to the PC -- this is music that came with the SMS I bought and I don't want it. I will now do a clean out of HDD and reset it to factory status with some (Russound tech support help). Then start uploading my files to SMS.
I have 2 questiond also: 1. Does anyone have the format or format instructions to prepare MP3 for use with the "HDD Import" option ? Supposedly this is a format used by ReadytoPlay and Ripstation, but I assume the mp3 format is something anyone can do if they have the specs. 2. Does anyone know how to prepare and upload Themes in SMS3 from outside instead of creating them one by one in the SMS user interface? Thanks in advance.
chansuresh is offline
post #15 of 42 Old 05-11-2014, 12:40 PM
iap1's Avatar
Hi I have a HDD crash on my SMS3, can anyone help me to get an image to make it work again.
iap1 is offline
post #16 of 42 Old 05-16-2014, 08:12 PM
mpr5231's Avatar
I have a working SMS3 160 GB, let me know if you'd like a disk image.
iap1 likes this.
mpr5231 is offline
post #17 of 42 Old 06-07-2014, 10:15 PM
freesuncc's Avatar
Hi - have a dead SMS3 and would love a copy of the image.  How can you share?
Freesuncc
freesuncc is offline
post #18 of 42 Old 11-06-2014, 08:00 PM
Liked: 0
Exclamation
Do you still have a disk image available?
My dad's unit died, but i was able to replace the capacitors on the motherboard and get it booting again.
However, i must have done something to the drive when i backed it up in windows. It boots linux to the sms splash page, but then the whole system reboots.
I think im very close to fixing this for him, but really need the image at this point. Please let me know.
Duxcub is offline
post #19 of 42 Old 12-16-2014, 02:06 PM
phili76's Avatar
Liked: 0
hi,
Seems another sms3 died. I will check the capacitors tomorrow maybe the hdd is still working @mpr5231 : do you still have the disk image in case the hdd is dead?
thank you from Austria
philipp
phili76 is offline
post #20 of 42 Old 01-20-2015, 12:28 PM
Liked: 0
one more image needed
Hi
my SMS3 hardrive died as well. Could someone upload an image to my onedrive or dropbox?
thanks a lot,
Johannes also from Austria :-)
@phili76 (German) hast du schon ein Image gefunden/bekommen?
uhb80 is offline
post #21 of 42 Old 01-21-2015, 08:56 AM
phili76's Avatar
Liked: 0
Hi uhb80,
fortunately "only" the caps dried out. I replaced them and all working again.
I also did a backup, just in case...
@uhb80 : kein Problem. schicke dir eine PN.
Philipp
phili76 is offline
post #22 of 42 Old 01-21-2015, 08:59 AM
phili76's Avatar
Liked: 0
need some more posts for pm... grr
phili76 is offline
post #23 of 42 Old 01-22-2015, 06:08 AM
Liked: 0
don't know if it is allowed to post e-mail adresses here, if not i'm sorry
please contact me at sms3 (at) reflex (dot) at
thank you
uhb80 is offline
post #24 of 42 Old 01-29-2015, 05:24 AM
Liked: 0
thank you
@phili76 bitte melden! :-)
uhb80 is offline
post #25 of 42 Old 01-29-2015, 09:50 AM
phili76's Avatar
Liked: 0
You have got mail :-)
philipp
phili76 is offline
post #26 of 42 Old 02-07-2015, 06:42 PM
mpr5231's Avatar
@Duxcub @phili76 I do have the disk image. Sorry I've been away for a while... message me if you're still needing one!
mpr5231 is offline
post #27 of 42 Old 03-19-2015, 08:21 PM
Liked: 0
SMS3 image
I'm too new here to be able to PM you. I have an SMS3 with enough bad sectors that Acronis can't make a decent image of it. Can you PM me?
Thx.
dwalterm is offline
post #28 of 42 Old 03-24-2015, 10:48 AM
Liked: 0
has anyone tried an ssd with sata to ide adapter in a SMS3? That should reduce the drive failures as well as reduce the heat, reduce the power required and noise..... and possibly speed it up some.
dwalterm is offline
post #29 of 42 Old 10-21-2015, 02:34 PM
Liked: 0
Do you still have the image for the SMS3? I need a copy as my disk died. Anyway I can get a copy from you?
mmancuso13 is offline
post #30 of 42 Old 10-21-2015, 02:35 PM
Liked: 0
Smile Looking for SMS IMAGE
Reply Home A/V Distribution
