Messed up BAD! Accidentally cut long in-wall HDMI Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-03-2013, 07:59 AM - Thread Starter
pjavan's Avatar
So moved into a house after 3 months of remolding and started to terminate all the cables at the home distribution hub.
Well I accidentally cut one of my long HDMI runs that goes to another floor!!!
It's the RedMere 60 ft HDMI (directional) cable from MonoPrice. Re-running this would mean a lot of cutting throughout a brand new house.
Does ANYONE know of a "it was worth a shot" attempt at repairing this?
PJ
pjavan is offline
post #2 of 18 Old 09-03-2013, 08:39 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
Good luck on this one, your over do. If you do not have a long enough tail on the connector to work with get a short RedMere to sacrifice, and maybe get one for just practice as this could be a one shot deal.
http://www.avsforum.com/t/1284801/how-to-fix-an-hdmi-cable-for-real
Phil17108 is offline
post #3 of 18 Old 09-03-2013, 09:23 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Ick. Does the cable move at all? If so, you can use it as a pull string to pull a new cable through. But if the replacement HDMI cable can't be pulled through due to the connector size (likely), pulling a cat6 cable and using an HDBaseT solution instead is probably your solution. If you've got any cat6 runs to that location, use that.
jautor is offline
post #4 of 18 Old 09-03-2013, 05:35 PM
AV_Integrated's Avatar
Quoted: 973 Post(s)
Liked: 718
You did pull a cat-5/6 cable along with the HDMI cable as repeatedly recommended didn't you?
This is always a requirement IMO because HDMI will be dead in 5 or 10 (or 50) years and then the next solution will still offer some cat-x solution (most likely).
Otherwise, you are in for a real headache as I've yet to hear of a successful repair of a HDMI cable.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 18 Old 09-03-2013, 09:26 PM - Thread Starter
pjavan's Avatar
Yeah I ran Cat 6 through out house. I suppose that can be my backup. I'm going to try the fix phil posted to see if that works. I'll keep the thread posted to see how the project goes!!!
pjavan is offline
post #6 of 18 Old 09-03-2013, 09:52 PM
jautor's Avatar
Liked: 777
The Redmere cable has active components to re-equalize the signal at the TV end. The cable construction is different than a 'normal' HDMI cable. So I think your chances of success are low, but certainly nothing to lose by trying. See this app note about the Redmere solution which might give you some useful info. I just grabbed one of their notes dealing with HDMI products - the cable may have a different model chip in their product line, but the info should be valid regardless:
http://redmere.com/download.php?file=626
Jeff
jautor is offline
post #7 of 18 Old 09-03-2013, 10:15 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
It's easy to match new paint color. Repairing a drywall hole (or 2) is $100 or less, from a pro drywaller/painter - cheaper than an extender over catx.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #8 of 18 Old 09-03-2013, 11:50 PM
Colm's Avatar
Liked: 94
Be aware that any fix will be less than perfect, regardless of what the guy in the link said. It may yield a flawless picture today, but not work well in the future when you bump up the bit rate. A TDR will be able to pinpoint exactly where the splice was made when done by a pro, let alone a noob.
You are better off in the long run pulling a new cable or using the existing Cat 6 with an extender, preferably HDBaseT.
Colm is offline
post #9 of 18 Old 09-04-2013, 11:20 AM
alk3997's Avatar
Liked: 92
+1
And if you splice incorrectly, you could damage a connected component. I've read some horror stories that are unfortunately true including smoke coming out of the HDMI connector on the component.
(Take whatever Colm tells you about HDMI to the bank)
alk3997 is offline
post #10 of 18 Old 09-16-2013, 06:19 PM - Thread Starter
pjavan's Avatar
Alright everyone. I decided to give the repair a shot. Here's the results on a 60 foot Redmere HDMI cable. took a while but It works beautifully!!!! I wrapped some shield between each one using foil and then electric tape.
pjavan is offline
post #11 of 18 Old 09-16-2013, 06:55 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
That's awesome!
Glad it worked out!
Neurorad is offline
post #12 of 18 Old 09-16-2013, 09:08 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
I would love to see what you did to the impedance at that point in the cable. Don't suppose you have access to a TDR?
Regards, Frederick C. Wilt
fcwilt is offline
post #13 of 18 Old 09-17-2013, 11:48 AM
Glimmie's Avatar
Quoted: 730 Post(s)
Liked: 592
I think you could get away with a splice if done carefully, that is keeping the pair untwist to a half inch, use a 1/8in solder splice and keep the whole thing tight with an overall shrink boot. That would probably work for most systems.
But this? I too am very surprised it works at all over that distance.
Glimmie is online now
post #14 of 18 Old 09-17-2013, 11:53 AM
alk3997's Avatar
Liked: 92
Originally Posted by Glimmie View Post
Exactly.
Please don't try this at home - oh wait, he did. I hoping that didn't go back into the wall.
alk3997 is offline
post #15 of 18 Old 12-15-2013, 04:31 PM - Thread Starter
pjavan's Avatar
I actually took some aluminum foil and did a ghetto shield around it with duct tape....yes duct tape. it's the most rigged cable you'd ever see, but 3 months strong now!
pjavan is offline
post #16 of 18 Old 12-15-2013, 08:18 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
You really shouldn't admit to this kinda stuff on a public forum - really - it's embarrassing!!! wink.gif
fcwilt is offline
post #17 of 18 Old 12-16-2013, 07:16 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
It was an off the top of my head idea, I had run across that post and linked it. Glad it worked out.
post #18 of 18 Old 12-16-2013, 03:36 PM
Colm's Avatar
Liked: 94
Colm is offline
Reply Home A/V Distribution
