TV in bedroom, AVR in kitchen, Cat6 in wall - need HDMI over cat6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-04-2013, 04:26 PM - Thread Starter
dfn
dfn's Avatar
Looking for advice on what to buy for my parents. The setup is the following:
TV in bedroom, AVR in kitchen, Cat 6 cables going from kitchen to bedroom (in walls and ceiling), not longer than 80 feet in total length. Need to connect AVR to TV. AVR = HDMI, TV = HDMI.
From these two solutions, which would you recommend and why?
http://wyrestorm.com/catalog/40m131ft-1utp-with-ir-edid-adjustment
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10914&cs_id=1091401&p_id=10225&seq=1&format=2
Are there any other solutions you'd recommend? The only reason I linked the above two is because one is offered by the electrician the homebuilder contracted out, and the other is what I found searching these forums. This is totally new territory for me...would appreciate any advice.
dfn is offline
post #2 of 13 Old 09-05-2013, 01:09 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
HDBaseT is usually the most stable.
ifor is offline
post #3 of 13 Old 09-05-2013, 08:04 AM
M1chael's Avatar
Quoted: 12 Post(s)
OP if you don't want to spend so much money on a HDBaseT solution and the run is under 100 feet or so...you may want to also consider an simple hdmi extender like this:
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=8121&seq=1&format=2
or
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10110&cs_id=1011012&p_id=6532&seq=1&format=2
M1chael is offline
post #4 of 13 Old 09-05-2013, 11:51 AM - Thread Starter
dfn
dfn's Avatar
Thanks for the replies!
I forgot to mention, there are three cat6 cables going from the kitchen to the bedroom. Not sure if that changes anything?
dfn is offline
post #5 of 13 Old 09-05-2013, 12:04 PM
M1chael's Avatar
Quoted: 12 Post(s)
The options I just stated in my last post (hdmi extender) would use two of those cables leaving one extra for anything else...(i.e. ir emitter, etc)
M1chael is offline
post #6 of 13 Old 09-05-2013, 08:54 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
HDBaseT has 2-way ir built into the units. Usually.
I use the SnapAV HDBaseT baluns as they only require power one the transmitter end, saving space at the display. Especially when wall mounting the display.
ifor is offline
post #7 of 13 Old 09-05-2013, 10:53 PM
bluetv's Avatar
To M1chael,
The two HDMI over two Cat6 extenders you mentioned support HDMI1.2 only (according to the manuals that come with the product page). Any similar devices that support HDMI 1.4b?
bluetv is offline
post #8 of 13 Old 09-06-2013, 01:13 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
Yes.
HDBaseT supports 3D, 1080p, Deep Color 36-bit, 4K, Dolby and DTS HD.
ifor is offline
post #9 of 13 Old 09-06-2013, 10:22 PM
bluetv's Avatar
ifor,
When you wrote 4k, does it mean it support HDMI 2.0 as well?
bluetv is offline
post #10 of 13 Old 09-07-2013, 01:19 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
No. HDMI 2.0 is brand new and no one has any specs for it.
There is no hardware for it currently.
ifor is offline
post #11 of 13 Old 09-13-2013, 09:54 AM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
Ignore HDMI versions numbers and look for Feature support instead – with HDMI most features are ‘optional’ so you need to ensure you have the feature you require not the version.
Are you expecting Video + Audio via HDMI on the Bedroom TV or are you only looking for Video and using the AVR to Speakers in the bedroom?
How are you planning to control the Source/AVR from the bedroom?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #12 of 13 Old 09-13-2013, 10:02 AM
ekkoville's Avatar
or
I use the bottom piece from Monoprice that you linked to. Works like a charm along with IR. Also serves up your network if you want Ethernet to your TV for apps.
ekkoville is offline
post #13 of 13 Old 09-13-2013, 05:22 PM - Thread Starter
dfn
dfn's Avatar
AVR is powering speakers in the bedroom, so only video to the TV (bedroom).
The plan is to use an android tablet with iRule as a universal remote control, with 2 iTach devices (one in the kitchen for AVR + DCT/PVR, and another in the bedroom for TV).
Thanks for the helpful replies everyone!
dfn is offline
Reply Home A/V Distribution
