Can wireless router be inside cabinet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-11-2013, 01:15 PM - Thread Starter
hmunster2's Avatar
Quoted: 92 Post(s)
Liked: 32
This may seem like a rather dumb question, but never really thought that much about it before. I know that placement of a wireless router in the home makes a difference in the strength of reception in various areas, but is it influenced by being inside of a piece of furniture?
I would prefer to keep my router in our family room (central location and best reception there), but inside a piece of furniture.
Will this limit the distribution of my router?
hmunster2 is offline
post #2 of 3 Old 09-11-2013, 03:22 PM
PzNuts's Avatar
If there is any signal loss caused by the furniture it will be minor. I would be more concerned with other things around the router (nearby microwave, non-DECT cordless phones, etc) that may cause interference or even the age of your router itself. I keep mine downstairs in a central AV closet and the signal is fine throughout the house, but it is also a newer-ish router.
PzNuts is offline
post #3 of 3 Old 09-11-2013, 03:42 PM
DGF
DGF's Avatar
Liked: 39
You'll definitely get signal degradation, but without complex analysis, the only way to know the impact is to try it out. I have a wireless router located on a shelf inside a run of solid birch cabinets - I get strong signals at one end of the house (approx. 70' away, on a different floor), but very weak transmissions in an adjacent room that is maybe 25'-30 away. It all depends.....smile.gif
DGF is offline
Reply Home A/V Distribution
