Using HDMI Matrix Switch with AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-17-2013, 02:40 PM - Thread Starter
dstlcm's Avatar
I have multiple sources that I want to view and two different tv in separate rooms. One of the TV will have surround sound and the other just using the TV speakers. Is it possible to use a 4x2 matrix hdmi switch to connect my sources, and connect one output from the switch to my tv and the other output going to the AVR which in turn will provide video to my TV and also the surround sound audio? If this is possible will I lose any quality by doing this? I included a diagram
dstlcm is offline
post #2 of 3 Old 09-17-2013, 04:21 PM
jautor's Avatar
Quoted: 1322 Post(s)
Liked: 845
You will likely run into issues with digital / surround audio unless your TV supports it. Search for "HDMI common denominator" problems to get a load on this. The fix is to get an HDMI-based Soundbar for the other TV so that they have the same HDMI audio capabilities.
This also assumes both TVs are 1080p-capable, otherwise you'll have that issue, too...
Jeff
dstlcm likes this.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #3 of 3 Old 09-18-2013, 10:30 AM - Thread Starter
dstlcm's Avatar
Thank you for the reply jautor. That answered my questions.
dstlcm is offline
Reply Home A/V Distribution
