Need a way to mute/switch audio with a closed contact - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-19-2013, 10:43 AM - Thread Starter
DeltaNu1142's Avatar
I'm moving into a home with a Linear hardwired intercom system with a total of 8 stations and various in-ceiling speakers. I'd like to use the stations to play sound from a receiver. Using a Linear DMC-10AWP device, I can input sound to the Linear system via RCA cables. However, in order to mute the sound when the intercom is used, I need a box or other piece of hardware that will mute or redirect the sound upon contact closure from the DMC-10AWP (the 3.5mm mute output).
I was thinking that an A/B switch for RCA cables would work; when the contact is open, "A" or my audio source is selected, and when the contact closes, "B" or nothing (disconnected) is selected. However, I can't find one that works on a dry contact closure. Any other ideas? Is there a straight-through "mute box" out there I don't know about? There is no mute input on my Onkyo AVR.
DeltaNu1142 is offline
post #2 of 3 Old 09-29-2013, 02:52 PM - Thread Starter
No ideas, eh? No one has done or needed anything like this?
post #3 of 3 Old 10-04-2013, 09:40 AM
trx250r87's Avatar
trx250r87 is offline
Reply Home A/V Distribution
