Problems running a RF Modulator to another room. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 31 Old 10-21-2013, 12:46 AM
acesat's Avatar
You need to try plugging the coax output from the modulator into the main tv, and change the input to TV on channel 3. If you get a bad picture, it's probably the modulator. If the picture is fine, then it's probably something to do with the other TV itself.
acesat is offline
Reply Home A/V Distribution
