Help connecting HTPC to TV across the room. - AVS Forum | Home Theater Discussions And Reviews
Old 10-20-2013, 08:55 AM - Thread Starter
bkholy's Avatar
Hello,
I moved to a new place which is already wired for component video. Unfortunately my HTPC only has, HDMI, DVI-D, and D-SUB.
My TV has PC input, hdmi & component, so I am trying to figure out a way to connect HTPC (in a closet 35ft away) to my TV. Any suggestions? I tried wireless HDMI, but quality is distorted.
Suggestions are welcomed!
-Boris
bkholy is offline
Old 10-20-2013, 11:05 AM
AV_Integrated's Avatar
Quoted: 990 Post(s)
Liked: 728
The total wiring between the equipment location and your TV is the red/green/blue wires of component video? Or are there ANY other wires there at all? Cat-5e? Additional wires for something else? A second set of component video wires?
I'm at a loss if that is the only wires which exist between the two points.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
Old 10-20-2013, 10:07 PM
Matt L's Avatar
Quoted: 299 Post(s)
Liked: 266
Well there are DVI to Component adapters in a wide range of prices. I have no idea how well they work but certainly worth a try. Component inputs are every bit as good as HDMI so no loss of quality on that end.
Matt L is offline
Old 10-20-2013, 10:25 PM
Quoted: 990 Post(s)
Liked: 728
There aren't that many DVI to component video adapters out there. There are converter CABLES, but those aren't active. It assumes that the source is component video, which the PC may not be able to deliver.
So, if you are thinking something like this will work: http://www.amazon.com/PTC-DVI-Component-HDTV-Adapter/dp/B00068NSZA - You need to understand that this is not a converter, just an adapter cable. Analog output from a DVI connection will typically be RGBHV, not YCbCr (component), and those little cables/adapters won't do what is necessary.
Worth saying: The OP should check the capabilities of the video card in the HTPC as some video cards can output component video at 720p, or potential 1080i or 1080p and it may do so over the DVI output or it may do it over another connection on the card. I believe my video card on my PC offers this capability, but you should check.
Do you need audio out as well, or just HD video?
Something like this is an active HDMI to component video converter and it MAY work. Read the reviews, it is far from perfect....
http://www.amazon.com/HDfuryproTwo-Component-Converter-Support-Surround/dp/B009YP7Y56/ref=sr_1_3?s=electronics&ie=UTF8&qid=1382329423&sr=1-3&keywords=rgb+to+component+converter
Old 10-27-2013, 03:27 PM - Thread Starter
bkholy's Avatar
Thanks for the quick reply. I am going to answer all of your questions and comments in this post...
AV_Integrated: I only have three coax wires going from media closet to TV. The coax is terminated with BNC RCA cables. Hence, they were used for component connection. Sound is separate, so I don't really care about that.
I am using a Mini-ITX Zotac ionitx-a-u motherboard. DVI is digital only so I can't use dvi-component cable on it.
This is driving me crazy. I tried a HDMI to Component converter, but doesn't work perfectly. There is a converter for HDMI over COAX, but it's like $300. Don't want to spend that much money it.
I guess I will just move the HTPC next to my TV. Kind of sux, but I can't think of any other affordable options.
bkholy is offline
Old 10-27-2013, 04:05 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
There are HDMI-over-coax solutions that you could use, IIRC there's one for ~$300 these days...
jautor is offline
Old 10-27-2013, 06:00 PM - Thread Starter
bkholy's Avatar
$300!!! What's the resale value on these things? If I buy it now, and sell it a year from now?
bkholy is offline
Old 10-27-2013, 06:14 PM
jautor's Avatar
Liked: 781
As with most of this type of gear, market is small - you'd be lucky to get half back in resale. But why would you sell it if it works? But yes, if you can just move the HTPC and that's an acceptable solution, you can't beat free...
jautor is offline
Old 10-27-2013, 08:11 PM - Thread Starter
bkholy's Avatar
I am living in the rental for a year. Hopefully won't need after that.
bkholy is offline
