Keystone speaker post for use with spades - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-22-2013, 09:44 AM - Thread Starter
UNCHeel's Avatar
I am putting in a pair of boxes on opposite sides of my home theater/media room to run several cables including the rear and side speakers of my 7.2 setup. Connections will include speaker posts, RCAs, cat6, F connector, etc. I plan to assemble custom plates using some type of keystone system. My current speaker cables are terminated in spade connectors. I was speaking with someone at Leviton about my plans and he indicated that their speaker binding posts in their QuickPort system were not compatible with spade connectors. I feel I am about show my ignorance here, but I thought spades could be used with all binding posts. After closely reading the specs on some of the various keystone type speaker binding posts I see that they don't specifically mention spade connectors.
Does anyone know of any keystone type binding posts that can be used with spades?
TWC Raleigh, NC
Motorola DCX3510-M
UNCHeel is offline
post #2 of 7 Old 10-22-2013, 10:07 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
The keystone versions I've seen aren't "5-way binding posts", which is what you'd need for spade lugs:
http://en.wikipedia.org/wiki/Binding_post
The keystones accept either bare wire or a banana plug (individual).
jautor is offline
post #3 of 7 Old 10-22-2013, 11:34 AM - Thread Starter
UNCHeel's Avatar
Thanks for the terminology. A quick cross reference of keystone and 5 way binding posts narrowed my search down. Found some from Wired Home. They appear to be 5 way on both sides which will make installation a breeze. BUT, wow is the price up there, 4 to 5 bucks each.
TWC Raleigh, NC
Motorola DCX3510-M
UNCHeel is offline
post #4 of 7 Old 10-22-2013, 01:12 PM
jautor's Avatar
Liked: 781
Yep... Re-terminating or swapping speaker cables for banana-plug'ed ends might be a better choice. And if those are "expensive" speaker cables, sell them and finance a nice set of Monoprice wires and pocket the difference. biggrin.gif
jautor is offline
post #5 of 7 Old 10-22-2013, 03:55 PM - Thread Starter
UNCHeel's Avatar
Nope they are home built. I just always felt like spades were more secure than bananas.
Getting back to the original question. I am starting to think the guy at Leviton, (and the guy at Monoprice for that matter), doesn't know what he's talking about. I did some more research, and I can't figure out how a binding post won't work with a spade. Leviton makes a female banana plug keystone. And that is all it does. It doesn't have a threaded ring that tightens down. They also have a binding post keystone. They don't claim that it is five way. But how can that not work with a spade? I can see if the post wasn't side drilled then you could not use pins or attach a bare wire through that hole. But that would still leave you with a 3 way, Banana, wire wrapped around the post, and spade.
Any thoughts/comments on this?
TWC Raleigh, NC
Motorola DCX3510-M
UNCHeel is offline
post #6 of 7 Old 10-22-2013, 09:21 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
You're exactly right--Leviton makes an insert specifically for banana plugs, and another insert with a binding post. I would agree with you in that I can't see how a spade wouldn't fit in these binding posts. I might be concerned if you were using a 6-port decora insert for your keystones, as this would put your binding posts very close together. I wouldn't be so concerned with a 4-port decora insert or a 6-port standard single-gang plate.
cshepard is offline
post #7 of 7 Old 10-23-2013, 09:41 AM
AV_Integrated's Avatar
Quoted: 990 Post(s)
Liked: 728
You just need any generic 5-way binding post.
Monoprice has ones which are in decora shells already:
http://www.monoprice.com/Product/?c_id=104&cp_id=10425&cs_id=1042503&p_id=3326&seq=1&format=1#largeimage
...along with ones which are in keystone connectors:
http://www.monoprice.com/Category?c_id=104&cp_id=10426
The description clearly states that it is compatible with spades...
http://www.monoprice.com/Product?c_id=104&cp_id=10426&cs_id=1042603&p_id=8436&seq=1&format=2
Under $1.50 for the ones from Monoprice.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
Reply Home A/V Distribution
