Used to be in the industry, out of touch with the current tech, Advice for new construction - AVS Forum | Home Theater Discussions And Reviews
Old 10-26-2013, 02:27 PM - Thread Starter
dizziness's Avatar
I'm wiring my brother-in-law's new home for distributed audio and video. I used to work in the industry (8 years ago) and am out of touch with the current offerings. Here's a brief run down of the configuration:
12 rooms with home-runs for a pair of in-walls or in-ceilings
Four rooms with dual CAT6, RG6QS home-run drops for HDTV
One "theater" space with home-runs for two on-wall HDTV locations, in-wall/in-ceiling surround, dual subs.
My sister-in-law uses iTunes and Satellite radio for audio. She already uses a few Airplay speakers. So, it would make the most sense to go iPad/iPod touch for controllers. That said, I think I should add control pad CAT6 drops to each room wired for speakers.
Who has a multi-room audio setup using Airplay? What about the theater? Just use CAT6 baluns for HDMI and control? Ask away.
Chris
dizziness is offline
Old 10-26-2013, 04:38 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 781
Lots of threads here you can read for a lot of the basics for whole house audio (WHA) systems...
Any room with WHA speakers should have a cat5e / cat6 run to a potential keypad location in that room.
If anything, run one more cat6 to each potential display location (total of 3) for the most flexibility. The inexpensive HDMI distribution systems use dual-cat5 runs.
Airplay can be incorporated into any WHA system using an Apple Airport Express, although the streaming audio support on systems from the big players (NuVo, Russound, Sonos) and others are generally a better solution that tying up the iDevice as the streaming source.
Theater space deserves a bunch of wire to a bunch of locations, can't tell more without a diagram or a better description of the goal of that space. In general, avoid HDMI runs in-wall between rooms, but one between an AV rack and the projector / TV location within a room is good. But those should always be accompanied by a flex conduit for futureproofing.
Jeff
jautor is offline
Old 10-31-2013, 08:31 AM - Thread Starter
dizziness's Avatar
Good response. Thanks for the help.
Old 10-31-2013, 10:41 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
My personal opinion is I don't like RG-6 Quad. Belden (7915A) makes a 3 gig. cable with very good shielding and you don't need special RG-6 F connectors.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
