12-channel power amp for whole house audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-29-2013, 07:53 PM - Thread Starter
meoge's Avatar
I'm looking for suggestions for a rack mountable 12-channel amp to use with a 6 zone Control4 system. I've been recommended an Episode amp and wanted to know what others use in their systems.
meoge is offline
post #2 of 9 Old 10-30-2013, 01:41 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
The Episode is a nice piece.
It's digital, so it's cool running and very efficient. It is also a lot smaller than most other 12 channel amps.
ifor is offline
post #3 of 9 Old 10-30-2013, 06:50 AM
Vincent941's Avatar
Control4 has a 4 zone amp and a 8 zone amp they both are great. I have the 2 8zone amps and love them all you to is but the rack mount kits for the amps they are very cheap.
Vincent941 is offline
post #4 of 9 Old 10-30-2013, 08:53 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
Control4 amps are nice. They have lots of power, but the 8 zone isn't cheap. I use Sherbourn, not as much power, but enough for background music and parties. Check eBay
Here's one:
http://www.ebay.com/itm/Sherbourn-PA-12-45-Power-Amplifier-12-Channel-Amplifier-w-BONUS-C-12-System-/290996534391?pt=US_Home_Audio_Amplifiers_Preamps&hash=item43c0bebc77
BllDo is offline
post #5 of 9 Old 10-30-2013, 10:37 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I think most any 12-channel amp would work fine, as far as sound goes. Almost all multichannel distributed audio amps are digital, nowadays.
Are there any bells or whistles needed on the amp, for use with the C4 system? Looking at one the Episode multichannel amp webpages, I see at least one offers 'audio-sensing', and has a 12V trigger. If those will be needed, and you're buying a different one, you need to do some homework.
Niles, Speakercraft, Sonance, HTD, Elan, Dayton Audio - and many more.
I think Episode is fine, and easy - no hassles. If it doesn't work, the installer is responsible for troubleshooting, fixing, and replacing. I would say that's worth a premium.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 9 Old 10-30-2013, 04:49 PM - Thread Starter
meoge's Avatar
Thanks for the advice. I was just trying to see if I could save some money by getting the amp myself instead of having the integrator supply it. I'm meeting with them tomorrow and will ask what the requirements are for the amp.
meoge is offline
post #7 of 9 Old 10-31-2013, 02:58 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
Can you save a little money by getting a different amp yourself? Yes.
But you are on the hook if anything goes wrong and you are the one who will paying for service calls and anything else when it does go bad.
If they supply it, the any issues will be theirs and they will have to correct it. At least until the warranty runs out.
ifor is offline
post #8 of 9 Old 11-01-2013, 04:42 PM - Thread Starter
meoge's Avatar
I took your advice and just went with the Episode Amps the integrator was offering. After looking around they seemed reasonably priced and I knew my integrator would stand behind them.
meoge is offline
post #9 of 9 Old 08-13-2014, 11:19 AM
Liked: 0
cheap alternative
I have installed this system many times. It is a cheap fix when compared to other systems out there but in the end i have seen more failure rates when compared to a niles or control4 systems. Also people forget to factor in source units. If its a budget thing then not a bad deal at all but if you can afford to i would go the russound root. episode ends up costing clients the same in service calls or just replacing the unit
CustomeInstall is offline
Reply Home A/V Distribution
