Streaming from iOS and android to Russound 4 Zone/Single Source Surface Mount HubA-H4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-31-2013, 05:23 PM - Thread Starter
ToddRG52's Avatar
I had a whole home system installed a few years ago with a Russound 4 Zone/Single Source Surface Mount HubA-H4. I am using only 3 zones, and intend to add another one over the winter. The audio input into the hub is the speaker output from my desktop PC, but I would like to change the input to a system that lets me stream from my iOS or android devices. Any thoughts on the hardware I need to add/change?
ToddRG52 is offline
post #2 of 2 Old 10-31-2013, 08:57 PM
jautor's Avatar
Quoted: 1307 Post(s)
Liked: 836
Bluetooth receiver if you're within range, or an Airport Express. iOS has Airplay, and there are Airplay apps for Android (no experience with them, but they're around, check reviews to see if they work well enough).
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
Reply Home A/V Distribution
