High Power Source Selector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-01-2013, 11:12 AM - Thread Starter
dfidler's Avatar
Hi All,
I seem to be a bit backwards with this question so please bear with me.
I have two amplifiers
  • Denon 2809 Class D (120W Peak)
  • Classe CA-5200 Class A/B (200W RMS)
I have one set of speakers.
The Classe system consumes around 400W of power from the wall sitting idle (about 1500W during a heavy bass note at volume) so I want to use the Denon when I'm listening to pop music, watching movies, etc.
So what I need is a reverse speaker selector that will allow me to select which amp to use with my speakers (because right now the Denon is basically just being used as an HDMI switch for my Classe system, something I'd like to change).
Unfortunately, I can't just use a speaker selector because:
  1. I have yet to find a multi-source speaker selector that rates above 150W RMS (I found one with 2 inputs and 4 outputs - overkill but it still only did 150W RMS)
  2. A speaker selector is likely to have a diode in there to prevent a surge back to the input, so simply hooking my amps up to the speaker outs and the speakers up to the selector's input is likely to cook the selector.
Has anyone heard of such an animal?
Note: I never crank my system up to the 200W ceiling but I still want the headroom on any selector that I might buy.
Cheers,
Dave.
F:Focal Electra 1038be, S:B&W 610XP (soon to be replaced)
dfidler is offline
post #2 of 8 Old 11-01-2013, 11:45 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
http://www.nilesaudio.com/product.php?prodID=DPS-1&recordID=Source%20Switching%20Systems&categoryID=Automated%20Switching%20Systems&catcdID=10&prdcdID=FG00003
jautor is online now
post #3 of 8 Old 11-02-2013, 05:17 AM - Thread Starter
dfidler's Avatar
Well that's about as ugly as it gets but I guess it's fixable with a new project box. Thanks mate! smile.gif
dfidler is offline
post #4 of 8 Old 11-02-2013, 07:13 PM
AV_Integrated's Avatar
Quoted: 984 Post(s)
Liked: 728
If you intend to completely power off the other amplifier when you don't want to use it, then this one will do the job for you automatically...
http://www.sonance.com/products/accessories/detail/25
I personally haven't used it, but it seems to cover your desires... maybe.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 8 Old 11-02-2013, 09:58 PM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
??? Why not use the pre-outs from the denon to fee dthe Classe amp?
And the amp isn't using 400w sitting idle.
ifor is offline
post #6 of 8 Old 06-07-2015, 12:07 AM - Thread Starter
dfidler's Avatar
Because the pre/pro on the Denon is crap by comparison.
Yes.
It is.
It consumes 400W when powered on and doing absolutely nothing.
The Classe CA5200 is a 5x 200W Class A/B amplifier with a 50w Class A bias. That means that for the first 50W of each of those channels, it is a Class A amp and is dissipating that 50W as heat at all times. The amp only starts to exhibit Class A/B characteristics when power requirements peak over that 50W mark.
At the time of the OP, I had already confirmed this with direct measurement.
dfidler is offline
post #7 of 8 Old 06-07-2015, 12:10 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Really? This is a 1.5 year old thread.
ifor is offline
post #8 of 8 Old 06-10-2015, 03:28 AM - Thread Starter
dfidler's Avatar
I've been away. Time does not necessarily make correct information any less relevant.
dfidler is offline
Reply Home A/V Distribution
Denon Avr 2809ci 7 1 Channel Multizone Home Theater Receiver
