Best tool and connectors for mini-coax for component? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-15-2013, 02:14 PM - Thread Starter
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
I've got a bunch of 5 cable mini-coax run to several locations in the new house. The idea is to be able to send component to those locations at some point.
Whose RCA connectors and tool should I be using to terminate them? I'm willing to spend to avoid finicky cheap stuff, so warnings on what to avoid are perhaps even more useful than what to get.
Tips? Warnings?
-Bill
wkearney99 is offline
post #2 of 6 Old 11-15-2013, 05:23 PM
Techphil's Avatar
I use liberty connectors and tools. it is a three piece connector and have never had a problem with them.
tip*** there are 25 guage and 26 guage mini coax. make sure you buy the right ones to match your wire.
http://www.*******.com/Liberty-Cable/CM-RGB26-RCA/74220/productDetail.php?utm_source=googleBase&utm_medium=feed&utm_content=CM-RGB26-RCA&gclid=CNL0_diE6LoCFdJ9OgodukAAdw
Techphil is offline
post #3 of 6 Old 11-15-2013, 08:29 PM - Thread Starter
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
STFW found Liberty Cable's website, thanks. While there I saw a video for their field HDMI connectors:
http://www.libertycable.com/cm_video_library.php?video=HDTERM
That looks like a handy solution.
post #4 of 6 Old 11-16-2013, 05:08 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Interesting that the HDMI conductors are not twisted. Never knew that.
That explains a lot.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 6 Old 11-16-2013, 05:59 AM - Thread Starter
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
Originally Posted by Neurorad View Post
Interesting that the HDMI conductors are not twisted. Never knew that. That explains a lot.
Don't know if that's 'all' cables or just their particular solution to the field-termination hassle of high-density connections like HDMI.
post #6 of 6 Old 11-16-2013, 10:06 AM - Thread Starter
wkearney99's Avatar
Quoted: 321 Post(s)
Liked: 128
What about using right-angled connectors, like these:
http://www.amazon.com/C2G-40997-Compression-Connector-Miniature/dp/B00127P57I
(Not BNC, of course, that was just the picture link I happened to copy/paste)
I'm thinking they might work better given the close clearances inside some of the wall boxes. All that wiring takes up room, and the connectors even more so.
Reply Home A/V Distribution
