Rack advice for AV + network - AVS Forum | Home Theater Discussions And Reviews
Old 11-22-2013, 04:37 PM - Thread Starter
scootss's Avatar
Hi all -
I'm in the midst of a new home construction (not our design, we bought when the studs were up, but pre-wiring), and I've been able to have most of the wiring terminate in a nice big utility room. I've run speaker wire for ceiling speakers and cat 6 for distributed hdmi over Ethernet (have my eye on that forthcoming octava unit).
I'd appreciate any advice on what kind of rack I should get for the utility room to support both the AV gear and light home networking equipment. It doesn't need to be pretty since it's hidden and if I can have one item to save a few bucks on, that could help with the WAF.
Rough list of equipment:
- octava hdmi matrix
- cable box or two
- Apple TV
- blu-Ray player
- receiver
- cable modem
- Apple time capsule (last gen)
- patch panel
Nothing has ears on it except for the octava, so I'm envisioning lots of shelves...
What would you recommend?
Thank you!
scootss is offline
Old 11-22-2013, 08:42 PM
AV_Integrated's Avatar
Quoted: 1000 Post(s)
Liked: 731
I would pick up a 40+ RU rack from Middle Atlantic or similar and drop some rack shelves into it.
A SLIM-5-26 rack is nice. They are deep at 26", and wide open. Not pretty, but you can get good wire management, and you can add shelves and move them around as you like.
Check your local Craigslist for potential listings as well.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
