VGA to RG6 Distribution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-24-2013, 06:42 AM - Thread Starter
IcedTea9974's Avatar
My home security system has to outputs for video, HDMI and VGA.
I want to feed some other TVs in the house so all anyone has to do is turn on the desired set to the specified channel and they can view the feeds.
The DVR for the cameras is in the room with my whole house distribution.
The HDMI feed connects via HDMI back to my LCD TV.
I would like to use the VGA connection to connect to my distribution amplifier via RG6.
I am trying to find how to go from VGA to RG6 or some similar.
IcedTea9974 is offline
post #2 of 13 Old 11-24-2013, 12:31 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
In short, with the switch to digital TV, there are no cheap ways of doing this anymore... A digital modulator that could accept the VGA input is ~$800-ish...
jautor is online now
post #3 of 13 Old 11-25-2013, 07:32 AM - Thread Starter
What about HDMI to RG6, I have seen some devices that range anywhere from $170 to $400.
post #4 of 13 Old 11-25-2013, 08:40 AM
jautor's Avatar
Liked: 777
Yes, but those are HDMI extender products, not modulators. They require a dedicated RG6 cable. If you have an RG6 line that you're not using for CableTV, that can be connected point-to-point (not split to several TVs), you can use those products. You could split the HDMI signal and run several of those, if your wiring will allow for it.
I assumed you're using your RG6 for CableTV from your description...
Jeff
post #5 of 13 Old 11-25-2013, 09:14 AM - Thread Starter
What if I used the HDMI extender and then into a modulator then into distribution?
post #6 of 13 Old 11-25-2013, 10:09 AM
jautor's Avatar
Liked: 777
You still need a modulator to work with your digital CableTV setup, assuming that's what you have.
That said, since you're connecting a device with VGA output and (probably) don't care about audio, the ZeeVee 100 might work for you. And as I went looking for pricing on that model, I see there's one going way too cheap on eBay:
http://www.ebay.com/itm/ZeeVee-ZV-100-Bundle-FREE-SHIPPING-/261324994977?pt=US_Video_Cables_Adapters&hash=item3cd82ef9a1
I'm not 100% sure this will work for you, but that might be worth the risk - I don't think that seller knows the MSRP of that box!
Jeff
post #7 of 13 Old 11-25-2013, 10:20 AM - Thread Starter
I actually have satellite (DISH) that is channel modulated from the DISH receiver into my distribution to various locations. I don't care about the audio as the cameras only contain video, Either way, VGA or HDMI as long as I can get a picture and send to any location that has a TV so the feed can be looked at anytime.
post #8 of 13 Old 11-25-2013, 10:33 AM
jautor's Avatar
Liked: 777
Ok, now that you've provide some information about your actual setup, maybe there is an answer. So you're distributing your DishNetwork in SD from the receiver's modulated (ch 3/4?) output?
Then a VGA-to-composite/S-video converter (not just a cable, but a converter) like this:
http://www.monoprice.com/Product?c_id=101&cp_id=10114&cs_id=1011407&p_id=4724&seq=1&format=2
into an frequency-agile modulator like this one from ChannelPlus:
http://www.amazon.com/CHANNEL-5415-Single-Channel-Modulator/dp/B000246TJK/ref=sr_1_3?s=electronics&ie=UTF8&qid=1385400748&sr=1-3&keywords=channelplus
will put the security DVR onto another channel that you can tune to. This works because you're still using analog video for your distribution.
post #9 of 13 Old 11-25-2013, 10:56 AM - Thread Starter
Yes the DISH is distributed in SD, it is controlled by a UHF remote. It is a dual tuner receiver and the 2nd output in SD and made to be distributed in the home. You can select whatever unused channel you want on the UHF band. I can try to take some pictures and post them within the next day.
post #10 of 13 Old 11-25-2013, 11:22 AM
jautor's Avatar
Liked: 777
Yep, you're set then. The solution I posted above will work. You could probably get away with a cheap channel 3/4 modulator - but I'd still recommend picking up a frequency-agile one. They're cheap these days, you can find them all over eBay used, too.
post #11 of 13 Old 11-26-2013, 04:02 PM - Thread Starter
The VGA-to-composite/S-video converter is powered by USB, which I need something to power it from 120V AC wall power, I need a transformer. When I was looking at it a little more in depth today that is when I noticed the power issue.
Any other suggestions for the converter? I looked at the other one they have but its a converter to VGA to use a computer monitor.
post #12 of 13 Old 11-26-2013, 07:30 PM
jautor's Avatar
Liked: 777
http://www.monoprice.com/Product?c_id=108&cp_id=10851&cs_id=1085101&p_id=8857&seq=1&format=2
But it's just a 5V device, so any decent 5V wall wart with the correct plug will do.
post #13 of 13 Old 11-27-2013, 07:55 AM - Thread Starter
Duh, I forgot about this things!!!
Reply Home A/V Distribution
