Let's talk power supplies for structured media cabinets - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-25-2013, 08:45 PM - Thread Starter
opto_isolator's Avatar
I have an A-bus structured media panel that I plan on adding additional modules to. The modules all require 24 volts. I hate those damn power packs that they sell to use in the media panel. Are there any alternatives that I can use, such as a switching power supply that I can mount in the structured media panel? I want to ensure I am to code, but don't want to stack 4 or 5 of the big plastic blocks in the cabinet if I can help it (one factor is cost). Anyone ever done anything like this:
http://www.amazon.com/Genssi-14-6A-Regulated-Switching-Supply/dp/B005CLDOW8/ref=sr_1_9?ie=UTF8&qid=1385437499&sr=8-9&keywords=24+volt+power+supply
opto_isolator is offline
post #2 of 7 Old 11-26-2013, 04:33 PM - Thread Starter
Would a switching power supply work, versus the linear ones? I've read that they could potentially induce noise into the power feeds.
post #3 of 7 Old 11-26-2013, 04:42 PM - Thread Starter
http://www.amazon.com/DLS-27-25-AUTOMATIC-BATTERY-CHARGER-SUPPLY/dp/B0074JVPKY
I'm thinking this is a good one to go with based on the reviews, and design specs. It's good for up to 25A, at 24VDC.
post #4 of 7 Old 11-26-2013, 04:56 PM
SAM64's Avatar
Liked: 78
Use the first one you linked to. Don' t use a 55 Amp battery charger.
There isn't much electronic equipment around these days that doesn't use an SMPS.
SAM64 is offline
post #5 of 7 Old 11-26-2013, 07:32 PM - Thread Starter
Thanks for the reply. Is there a specific reason that you recommended the first one over the second one? The specs say that it can function as a power supply or battery charger.
post #6 of 7 Old 11-26-2013, 08:04 PM
SAM64's Avatar
Liked: 78
You don't need 55 Amps of DC for anything in that cabinet, plus the specs don't match the picture, so who knows what you're getting.
The first one is probably a lot cleaner on the output as well.
SAM64 is offline
post #7 of 7 Old 11-26-2013, 09:22 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 919
The first one also has gooder engrish:
Originally Posted by http://www.amazon.com/Genssi-14-6A-Regulated-Switching-Supply/dp/B005CLDOW8/ref=sr_1_9?ie=UTF8&qid=1385437499&sr=8-9&keywords=24+volt+power+supply
Genssi 24V 14.6 AMP 350W Max Power Supply. Known for quality that surpasses no name brands and generics you find everywhere else.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home A/V Distribution
