HD Satellite signal to two systems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-28-2013, 10:44 AM - Thread Starter
triangledave's Avatar
Hello,
I have a VIP 722K Dish Receiver, a Yamaha RX-V371 Home theater in a box and an Onkyo TX-NR 616 Home Theater amp.  The Yamaha is connected via HDMI to an HD Mitsubishi DLP tv and the Onkyo is connected to a new Epson HD projector via HDMI.  One of the reasons I updated the projector and Onkyo is to be able to have HD TV on the projector.
Room 1
-TV
-Yamaha
-Yamaha Receiver
-Dish Receiver
-Powered HDMI Splitter
     The splitter receives satellite on the input and the the 2 outputs are to the Yamaha and to the Onkyo
Room 2
-Projector
-Onkyo Receiver
The goal is to be able to watch TV on one or both systems at any given time without much fuss.  I understand that it is the same signal, so the same program will be showing on both systems.  I have an SQ Blaster system to be able to control the receiver from the home theater room.
The challenge is that when I try to run both, the whole thing quits and I get blue screens.  The only way things work now is if I power down the splitter and unplug the output to the Yamaha, then I get a picture on the projector.  It is the same thing to watch TV through the Yamaha.  I can leave the cables plugged in if only one Home Theater Amp is on.  Once the 2nd amp is turned on, I loose the signal.
While I'd like to be able to watch both at the same time, the more basic goal is a simple system that does not require powering down a splitter and/or resetting Dish receiver if both amps happen to be on.
Thank you for any suggestions and/or directions to point me in for trouble shooting.
triangledave is offline
post #2 of 7 Old 11-28-2013, 01:46 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Try bypassing the Yamaha and run HDMI from the splitter directly to the DLP, see if that changes the behavior.
jautor is online now
post #3 of 7 Old 11-28-2013, 01:50 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
'Powered HDMI Splitter' - what is the splitter you are using?
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #4 of 7 Old 11-28-2013, 07:20 PM
acesat's Avatar
why not use the component out for one of them?
acesat is offline
post #5 of 7 Old 11-28-2013, 07:54 PM
jautor's Avatar
Liked: 777
Oh, now, why didn't I remember that option... And I'm usually the one recommending component outputs... cool.gif
post #6 of 7 Old 11-28-2013, 08:56 PM - Thread Starter
Great ideas.  I've tried two different HDMI splitters with the same results.  I purchased the splitters on Amazon, neither has a name brand on it.  One of them was used successfully to distribute a Popcorn Hour Media player signal.
I am guessing that my issue is caused by the signal going into two receivers and then a device from each receiver.  I am going to first try the component video and optical sound out (I should have both cables).  As long as the pic and sound is not noticeably lower quality, I think that approach is the winner.  Hopefully the simplest solution will be the best--that totally eliminates the HDMI issue.
I guess I was so fixated on HDMI connections, I didn't even think of the component approach.
If that does not work, I'll plug HDMI directly into DLP TV.
Great suggestions, will report out as soon as I've changed the cables.
Thank you.
post #7 of 7 Old 11-29-2013, 01:06 PM - Thread Starter
Worked like a charm--I connected the dish receiver to the Yamaha via RGB and optical audio, then out to DLP TV using RGB out from Yamaha. No noticeable change of pic quality on DLP TV. Dish HDMI out goes straight to Onkyo input. Can watch TV in both rooms at same time. Very clean and simple solution, thank you. Even better, I had all the cables that I needed.
Reply Home A/V Distribution
