What would be the best way to make this work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-17-2013, 12:14 PM - Thread Starter
Wil Horneff's Avatar
I am trying to run a line from my ipad to three televisions so that they can broadcast what's on the ipad.  I have a choice to buy ipad to component connectors or ipad to hdmi connectors.  There is going to be approximately 100 feet between the ipad and the televisions.  I've read through the forum enough to see there are issues splitting hdmi and wasnt' sure if it was better to use component or if I just needed an hdmi splitter and an amp.  Any suggestions on what equipment to buy to get this done would be really appreciated.
Wil
Wil Horneff is offline
post #2 of 12 Old 12-17-2013, 01:22 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Component video would be much easier and avoids all the HDMI headaches. Use the CE Labs AV400COMP distribution amp and you can go 150' over component...
http://proav.celabs.net/av-products/av-distribution/component-amplifiers/av400comp/
Wil Horneff likes this.
jautor is online now
post #3 of 12 Old 12-17-2013, 01:43 PM - Thread Starter
Thanks a ton for the advice.  So basically all I need is to plug the component ipad adaptor into this and run component lines to all tvs and I'm all set?
post #4 of 12 Old 12-17-2013, 03:29 PM
jautor's Avatar
Liked: 777
Assuming the iPad component adapter works the way you need it to, yep...
post #5 of 12 Old 12-17-2013, 03:47 PM
tadr's Avatar
airplay isn't an option?
tadr is offline
post #6 of 12 Old 12-17-2013, 07:52 PM - Thread Starter
Wonderful thanks a lot
post #7 of 12 Old 12-17-2013, 07:53 PM - Thread Starter
I talked to an apple tech who said I couldnt' do it because I'd have to have 3 apple tv's and therefore 3 iphones
post #8 of 12 Old 12-17-2013, 08:31 PM - Thread Starter
Last question Jautor can you give me a good reccommendation for good quality cables or will any pretty much do the trick?
Wil
post #9 of 12 Old 12-17-2013, 08:32 PM - Thread Starter
Whoops I couldn't respond with your link.  Any reccommendations about a good quality 100 ft component cable or will any pretty much do the trick?
post #10 of 12 Old 12-17-2013, 09:18 PM
jautor's Avatar
Liked: 777
Monoprice:
http://www.monoprice.com/Category?c_id=102&cp_id=10235&cs_id=1023507
Or you can buy lengths of 3x RG59 coax and terminate them yourself. The triple-wire cable is easier to route around the room, but the pre-made cables are obviously an "easier" solution...
Jeff
post #11 of 12 Old 12-18-2013, 08:35 AM
tadr's Avatar
Are all three of the TVs nearby each other OR wired to a central location?
If so, you could just use 1 apple tv and an HDMI splitter.
tadr is offline
post #12 of 12 Old 12-18-2013, 11:31 AM - Thread Starter
They are all around 50 feet away from eachother.  I see what you are saying though and it seems like a great idea.  Unfortunately we have had major issues with the wifi and also getting mirroring to work consistently so I went ahead and went the component route.  Thanks a lot for taking your time to help me out tadr
Wil
Reply Home A/V Distribution
