Ethernet wired home help! only half the cat5 outlets are working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2014, 05:14 PM - Thread Starter
Bandondunes's Avatar
Hello all.  I'm a new home owner that recently purchased a "wired home."  But after plugging into some of the ports I realized they weren't activated (like the one behind the TV.)    It looks like I have 15 blue cables coming in from the wall to the patch panels.  But then I only have 8 options on the hub- which then takes me down to a router that has just 4 jacks.
A couple of questions...
1. I know i will likely need another hub with another 8 ports - but I can't figure out what or how to connect that to the patch panels.  I can't find any extra wires?
2. Do I need a new router with 16 ports?
Please help.  i'm a novice who is handy, but knows nothing about AV wiring.
The name of the black device is "Open House Data Hub" with 8 ports.
Bandondunes is offline
post #2 of 6 Old 01-24-2014, 06:30 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Use a second 8 port switch plugged into the router. You can either get another punch-down block for the other lines (and use jumpers to the switch) or just put RJ45 plugs on the lines and plug them into the switch.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 6 Old 01-24-2014, 06:50 PM - Thread Starter
thanks for the swith bit Oly - on the punch down block or the RJ45 -  Is that something I can do?  Not sure where the extra lines are that I need to connect to the RJ45 plugs.  How would you put RJ45s on the lines?
Thank you.
post #4 of 6 Old 01-24-2014, 08:54 PM
jkxmlr's Avatar
Oly is spot on. Need to refine your terminology a bit though. What your active lines are connected to in the cabinet is a punchdown panel, not a hub. A hub is a networking device at the lowest level. Next level is a switch, which you need either another or a larger one. i;e more ports. I think another punchdown panel is your best bet. RJ45 terminations can be done, but need to have a network cable checker, along with the tools.
jkxmlr is offline
post #5 of 6 Old 01-24-2014, 09:23 PM
jautor's Avatar
Quoted: 1317 Post(s)
Liked: 842
As already explained, an additional 8-port Ethernet switch can be used to expand your total port count from the 4 on your router. Connect the switch to the router, and you'll have a total of 10 ports available (after you connect the two devices together).
Nope, any Ethernet switch will do just fine - spend the extra $5 and get a Gigabit Ethernet version...
If the rooms you want to use are already wired to this patch panel "module", then you just need the Ethernet switch to give you enough ports. If the jack behind the TV ends in one of those blue wires hanging down below the box, you'll need another small patch panel module to properly terminate them. Yes, you could also terminate the cables directly with RJ45s. But since you've already got a decent start on the structured panel, I would go ahead and do it "right"...
Since that's an Elan panel, and there's a mix of brands of modules in there already, pick any patch panel module that will fit. The OnQ / Legrand ones are well made, but not cheap. Something with a flat back can be easy to mount with velcro-backed pads.
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #6 of 6 Old 01-24-2014, 10:01 PM
Colm's Avatar
Liked: 94
All the cables terminating on the top two punch down blocks on top are wired for telephone service, including the blue ones.
The bottom punch down block with the modular jacks labelled "Open House Data Hub" is simply a means to terminate eight cables with modular jacks.
The way everything is wired, you have eight circuits that can support Ethernet. If you want Ethernet on a cable that isn't one of those eight, you will need to rewire (that will require cutting and punching down one or more cables).
If you want more than eight Ethernet circuits, you can do as Jeff suggested and get another "Open House Data Hub" or equivalent, or just terminate the cables with a 8P8C modular (RJ45) plugs if they are long enough. It is not difficult, and you don't need a tester for home use. The cables will either work well, or not. And if they don't work well, you can always re-terminate them.
To support more than four Ethernet circuits, you need to add network hardware. Simplest way is as Jeff suggested, just plug a eight port switch into the router for eleven ports. However, depending on how you are going to use the network, it might be better to go with a sixteen port switch if you are going to have more than eight Ethernet circuits.
A gigabit switch is a good idea. It doesn't cost much more. It may save you an upgrade in the future. Just be aware that depending on how you are going to use your network, it may not give you any better performance, at least that you will notice. For one thing, the devices on either end, and everything in between, need to be gigabit capable or the switch will fall back to a slower speed for the link.
Colm is offline
Reply Home A/V Distribution
