Keystone RS-232 jack? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-25-2014, 09:46 AM - Thread Starter
lukasz74nj's Avatar
Is there an RS-232 keystone jack available out there? Given its size it may not be an option... Alternatively, can someone recommend an RS-232 wall plate?
I'm building a custom shelf and panel for all my A/V devices and want to provide an RS-232 connection to my TV for automation purposes.
Lukasz
lukasz74nj is offline
post #2 of 5 Old 01-25-2014, 10:34 AM
strohj's Avatar
Quoted: 14 Post(s)
strohj is offline
post #3 of 5 Old 01-25-2014, 10:39 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Use an RJ45 keystone, and a Cat5e patch cord. Then, at the device, use one of these:
A bit more work if you have to assemble the adapter, but also allows you to keep the rest of the wiring simple (RJ45s all wired correctly), since you can handle any gender-changing or null-modem swapping with the adapters...
Jeff
jautor is offline
post #4 of 5 Old 01-25-2014, 04:37 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
+1 on the adapter posted - use them all the time - makes changing the configuration of the rs232 connection (male, female, what signals on what pins, etc) simple.
Regards, Frederick C. Wilt
fcwilt is offline
post #5 of 5 Old 01-26-2014, 02:16 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://www.monoprice.com/Product?c_id=104&cp_id=10415&cs_id=1041501&p_id=1152&seq=1&format=2&ref=cj
http://www.remotecentral.com/cgi-bin/mboard/rc-custom/thread.cgi?14611
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
