Guidance for Ceiling Speakers Equipment Required - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-10-2014, 05:55 PM - Thread Starter
thiruvil's Avatar
Quoted: 16 Post(s)
I just moved into a new house with ceiling speakers. It has 5 areas with 2 speakers in each area with a volume control for each. Any idea what I need to get this setup (amp, hub, etc)? I intend to use this for background music with most likely using just one source maybe two.
thiruvil is offline
post #2 of 11 Old 03-10-2014, 07:21 PM
Choppermario's Avatar
If you are only looking to pipe the same source to one or more of the zones, all you need is an amplifier, source(s) and a speaker selector switch.
The amp doesn't have to have a crazy amount of power, 100W is plenty and you can probably even get away with less.
The source(s) can be pretty much anything that can connect to the amplifier.
Finally you will need a speaker selector switch like this:
http://www.monoprice.com/Product/?c_id=109&cp_id=10903&cs_id=1090305&p_id=8229&seq=1&format=1#largeimage
Just connect the speaker output of the amplifier to the input of the selector switch and connect each volume control to one of the outputs on the selector switch.
Now, there are more complicated and expensive solutions that will let you play different sources in each room, but without control wiring to each zone, control can get complicated.
Hope this helps?
-Mario
Choppermario is offline
post #3 of 11 Old 03-11-2014, 08:40 AM - Thread Starter
thiruvil's Avatar
Quoted: 16 Post(s)
Thanks for your help! Something like this work to power all of the speakers at the same time?
I assume using an extra receiver wouldn't work?
http://www.parts-express.com/dayton-audio-apa150-150w-power-amplifier--300-812
thiruvil is offline
post #4 of 11 Old 03-11-2014, 07:33 PM
The system I described above could drive all the speakers and the amp you linked to could do the job more than adequately.
Not sure what you mean by an extra receiver?
post #5 of 11 Old 03-17-2014, 08:36 PM - Thread Starter
thiruvil's Avatar
Quoted: 16 Post(s)
I hooked the speakers to the new amp to test the speakers and was unable to hear anything . I tried different sets of ceiling speakers but no luck. How can I test to make sure the speakers are connected?
thiruvil is offline
post #6 of 11 Old 03-17-2014, 10:28 PM
gerard143's Avatar
Quoted: 12 Post(s)
A 9 volt battery. No joke. You will hear a little thumb or scratchy type noise at the speaker.
Obviously turn the volume control knobs on the wall up
gerard143 is offline
post #7 of 11 Old 03-17-2014, 10:33 PM
gerard143's Avatar
Quoted: 12 Post(s)
That amp is not ideal. That's pretty much what you'd want for a subwoofer. It's crossover filter allows no frequencies above 150hz which is bass only. Unless the crossover was totally defeatable you will not be able to pass anything other then bass to speakers. That also is a very weak amp to power 12 speakers.
And kinda on an extra receiver. Say you had a 7.1 receiver. If it supports all channels mono as a surround mode then technically it would work. All channels stereo is a potential option as well just has some downsides
post #8 of 11 Old 03-18-2014, 12:20 AM
gerard143's Avatar
Quoted: 12 Post(s)
Ideally you want something like a niles zr6 or a nuvo multizone audio device. Zr6''s are on eBay a lot.
post #9 of 11 Old 03-18-2014, 05:17 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://cocoontech.com/forums/topic/26289-is-it-crazy-to-build-a-whole-home-audio-system-using-a-laptop/#entry211270
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #10 of 11 Old 03-20-2014, 04:55 PM - Thread Starter
thiruvil's Avatar
Quoted: 16 Post(s)
So tried touching the speaker wires on the 9v but haven't heard anything. Time to check if there are speakers behind the grill? smile.gif
thiruvil is offline
post #11 of 11 Old 03-20-2014, 08:20 PM
gerard143's Avatar
Quoted: 12 Post(s)
There should be. That's what holds the grills on
Reply Home A/V Distribution
