TV Ceiling Mount with Shelf - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-25-2014, 05:07 AM - Thread Starter
magicavs's Avatar
Hi All:
Newb here, awesome forum!!
I can't seem to find a TV ceiling mount WITH shelf for a ~30-40" TV.  I see wall mount types but not ceiling.  Please help.  I just don't want to mount anything to the wall.
Thanks!!
magicavs is offline
post #2 of 6 Old 03-26-2014, 10:23 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
Here is a component shelf, from Chief. It hangs below their ceiling mount - at least that's what their website says: http://www.chiefmfg.com/Series/FCA5XX%20Shelves
This is a GIS of "ceiling mount"+"component shelf"
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 6 Old 03-28-2014, 05:55 AM - Thread Starter
magicavs's Avatar
Neurorad,
Appreciate the help.  Chief is expensive as heck but looks real good.  I'm thinking of going with the NPT style.
Thanks again!
magicavs is offline
post #4 of 6 Old 03-28-2014, 08:48 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
NP. I think you just needed the correct term for the shelf - 'component shelf' - to find examples.
Neurorad is offline
post #5 of 6 Old 04-01-2014, 01:19 AM - Thread Starter
magicavs's Avatar
Ok back again.  Trying to hang the biggest size TV with cable box underneath, is really pushing it as far as space goes that I have in a particular spot.  This leads to another question.
What options do I have so I can mount the TV only on one side of the room, and have cable box and whatever else I want to attach on the opposite side next to me?  I don't think running a long HDMI cable makes sense?
Thanks!!
magicavs is offline
post #6 of 6 Old 04-01-2014, 09:01 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
If it's just a simple large cable box, it can be exchanged for a smaller cable box - the size of a deck of cards. Mount that on the back of the TV.
If it's a DVR, extend the cables.
Whole-house DVR can be located at any other TV, as far as I know, and still be used easily.
Neurorad is offline
Reply Home A/V Distribution
