2 Speaker cables in one channel through foam panel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-06-2014, 10:07 AM - Thread Starter
pex006's Avatar
Hi. I am new to running speaker cable so I was looking for some advice.
1.  I have these foam wall panels with prerouted wiring channels in them.  The channels are about 3/4" wide and aproximately 1/2" to 5/8" deep.  I  would like run (2) speaker cable down one of theses channels and out to a pair of speaker towers.  Is this safe or should I only run on per wiring channel.
2.  The channels are spaced 12 inches on center apart.  There with be a AC power cable in the next chase over about 12 inches away.  There will be 12 inches of foam between them.  Is that too close to the speaker cables?
3.  Is it better to drill holes in a blank wall plate and bring the cables to the speakers or terminate the cables at the wallplate and bring seperate cable from the wallplate to the speakers.
pex006 is offline
post #2 of 9 Old 04-06-2014, 10:22 AM
DGF
DGF's Avatar
Liked: 39
Hey Pex, welcome to the forum.
Sounds like you're in good shape, here are some thoughts:
1. You can run a whole number of low voltage (speaker) cables in the same channel, so a pair of twin cables, like you want to isn't an issue.
2. 12" separation between mains (110v) and speaker cables is used as a typical minimum number (in many cases going smaller is unavoidable) - so you're good here too.
3. My personal preference is to terminate in a wall plate and then use separate runs from the plate to the speaker - it gives a lot more flexibility, and just looks nicer (and more professional).
Hope that helps a bit.
Dave
DGF is offline
post #3 of 9 Old 04-06-2014, 10:50 AM - Thread Starter
pex006's Avatar
Thanks for the reply.  Is it acceptable to run the cables fastened to the bottom of floor joists in the basement if above a drop ceiling or should they be in a conduit or fastened to running boards just like running ac cables?.
pex006 is offline
post #4 of 9 Old 04-06-2014, 11:26 AM
DGF
DGF's Avatar
Liked: 39
I've never seen any requirements for running low voltage cable in a conduit, so you're safe running "au naturale" - just make sure you pin the cables at regular intervals.
DGF is offline
post #5 of 9 Old 04-06-2014, 11:29 AM - Thread Starter
pex006's Avatar
Thanks for all the help!
pex006 is offline
post #6 of 9 Old 04-08-2014, 02:26 PM - Thread Starter
pex006's Avatar
Can I run the subwoofer cable in these channels as well as the other speaker cables or should it be seperated?
pex006 is offline
post #7 of 9 Old 04-08-2014, 03:21 PM
SMHarman's Avatar
Quoted: 371 Post(s)
Liked: 120
Same channel is fine.
The primary rule is not to mix audio or data with electric.  Audio and audio in the same channel is fine.
SMHarman is online now
post #8 of 9 Old 04-09-2014, 01:29 PM
SAM64's Avatar
Liked: 78
They're all analog electrical signals.
The idea is to keep high current, low impedance away from high impedance signal cables, so mixing high current low impedance speaker wires with low voltage high impedance audio signal wires should be avoided.
SAM64 is offline
post #9 of 9 Old 04-09-2014, 07:47 PM - Thread Starter
pex006's Avatar
Ok thanks.
pex006 is offline
Reply Home A/V Distribution
