NuVo Keypads on one zone. - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2014, 06:44 AM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
I don't remember whether this topic has been discussed before but a "search" was unsuccessful.
Can you and if so how do you add a second NuVo NV-18GCP touch screen keypad? My example would be where you've added a impedance matching speaker selector to split a zone to master bedroom and bathroom ensuite but want a keypad in both locations to operate the same zone.
My Dream is offline
Old 05-05-2014, 07:57 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Yes, you can assign multiple keypads to a single zone. You can also assign multiple zones (sub-zones) to a single keypad...
But avoid that if you can - especially in the example you cite... Accidentally turning on a bedroom zone because you forgot to change the speaker selector can be hazardous to your health. biggrin.gif
My Dream likes this.
jautor is offline
Old 05-05-2014, 10:18 AM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
Thanks for the reply jautor, in my case it will be a Audioplex, A-B impedence matching speaker selector without the combination of the A+B so either the bedroom or bathroom speakers will be on at once. What I would like is to control both sets of speakers via one keypad which you say can be done.
Anyone care to share how to wire this up via a NuVo GC and the NV-18GCP pad, I would imagine the speaker selector wiring would remain the same?
My Dream is offline
Old 05-05-2014, 10:46 AM
jautor's Avatar
Liked: 777
You said the opposite (doesn't matter, as both cases work) - two keypads to manage one zone.
You just add another keypad to the system, same as if it were in another zone. The assignment to the zone is done via the keypad menu, in the Advanced Keypad settings for "slave to zone" ...
jautor is offline
Old 05-06-2014, 05:46 AM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
Jautor;
Thanks for the reply.
Yes, two keypads to monitor one zone, I've just added a speaker selector to manage two sets of speakers, but as you say, that's after the fact.
So if it's zone 1 then just assign the second keypad also to "zone 1" in the "slave to zone" menu?
My Dream is offline
Old 05-06-2014, 07:59 AM
jautor's Avatar
Liked: 777
Yep. It's all covered in the manual under the "'Advanced Zone Options" (or whatever it's called) section...
jautor is offline
Old 05-06-2014, 12:08 PM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
Thanks for the reply jautor, I'm now in search of a keypad to add to a zone that's not installed yet............smile.gif
My Dream is offline
Old 05-06-2014, 12:33 PM
jautor's Avatar
Liked: 777
They come up on eBay quite often for ~$100-150.
jautor is offline
Old 05-06-2014, 02:18 PM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
I've never seen new ones for $150.00 but on occasion do see them around the $150.00 including shipping for used ones. Maybe I'll get lucky..........thanks.
My Dream is offline
Old 05-06-2014, 02:26 PM
jautor's Avatar
Liked: 777
I've bought 4 of them new off eBay over the years for <$120 each, by just setting a saved search and not rushing to buy one... But I'd have no reservations buying a used one for less as long as the listing said it worked (such that eBay buyer protection would cover it if it didn't), or the seller had a return policy.
jautor is offline
