Looking for a RJ45 Tester - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-15-2014, 10:36 AM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
I've run about a dozen Cat5 cable to connect to the NuVo Grand Concerto keypads and want to test the lines. Would any Rj45 tester as shown in the photo be ok?
USB LAN Network/Phone Cable Tester RJ11 RJ12 RJ45 Cat5
Automatically scan mode, rapidly testing, the streamline shape is in accordance with the design of somatology
My Dream is offline
post #2 of 6 Old 05-15-2014, 11:04 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
Any RJ45 / Cat5 tester will be fine.
My Dream likes this.
jautor is online now
post #3 of 6 Old 05-15-2014, 12:19 PM
Waterboy77's Avatar
Quoted: 503 Post(s)
Liked: 231
Good old Monoprice
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #4 of 6 Old 05-15-2014, 01:40 PM
jautor's Avatar
Liked: 778
Originally Posted by Waterboy77 View Post
Good old Monoprice
Hmmm... Looking at both of those models (which appear to be the same make), I don't like the fact that you must look at displays on both ends to determine that a fault exists, and what to do about it. The instructions indicate that a missing / crossed wire will only show up on the display at one end.
I'd at least step up to this one:
http://www.monoprice.com/Product?c_id=105&cp_id=10524&cs_id=1052401&p_id=8130&seq=1&format=2
Which will show all the fault information from the primary end without having to check both...
Jeff
post #5 of 6 Old 05-15-2014, 01:41 PM - Thread Starter
My Dream's Avatar
Quoted: 27 Post(s)
Thanks for the reply and I should have waited a bit since I like the one jautor posted better. Unfortunately I already ordered the one on Amazon.
My Dream is offline
post #6 of 6 Old 05-15-2014, 07:57 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Somatology?
: a branch of anthropology primarily concerned with the comparative study of human evolution, variation, and classification especially through measurement and observation
WTF does that have to do with CAT cabling?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home A/V Distribution
