Audyssey setup for distributed system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-16-2014, 01:13 PM - Thread Starter
tritium6's Avatar
Quoted: 22 Post(s)
How do I run Audyssey setup if my receiver is 100ft away from its output? Do I get 100ft worth of extension cables for the setup microphone?
tritium6 is offline
post #2 of 7 Old 05-16-2014, 01:33 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Yep, or if the speaker wires can be intercepted in the room, bring the AVR into the room temporarily for taking the measurements.
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 7 Old 05-16-2014, 01:35 PM - Thread Starter
tritium6's Avatar
Quoted: 22 Post(s)
Wow, that's the only way I could think of but I guess I'm surprised it's that basic. Any advice on where to find such an extension cable?
tritium6 is offline
post #4 of 7 Old 05-16-2014, 01:40 PM - Thread Starter
tritium6's Avatar
Quoted: 22 Post(s)
Is it just an RCA cable? Perhaps a couple of these will do it: http://www.monoprice.com/Product/?c_id=102&cp_id=10218&cs_id=1021808&p_id=651&seq=1&format=2
Is attenuation a problem at that distance?
tritium6 is offline
post #5 of 7 Old 05-16-2014, 02:09 PM
jautor's Avatar
Liked: 852
Yeah, that's what I would try...
jautor is offline
post #6 of 7 Old 07-05-2014, 03:57 PM
dw886's Avatar
Quoted: 13 Post(s)
Did you get this figured out?
I read elsewhere that it's actually a mono cable (not a stereo cable). I need to go about the same distance to get to my A/V equipment.
dw886 is offline
post #7 of 7 Old 07-05-2014, 04:31 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
I would try using a 100' rca cable and just use one of the cables (not stereo). Then get a couple of rca to 3.5mm adapters to plug into the receiver and microphone.
cable:
http://www.monoprice.com/Product?c_i...seq=1&format=2
adapters:
and one of these to plug the microphone into:
ifor is offline
Reply Home A/V Distribution
