Using 12v Zone Triggers on Russound CAV6.6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-19-2014, 04:10 PM - Thread Starter
Liked: 0
I have 2 Russound CAV6.6's running 12 zones in my house. I'm looking to use the 12v Zone triggers to send IR commands to the TV in the zone and power them on and off as needed when the zone is on. Can anyone point me in the right direction on how I can accomplish this?
Here is my running setup:
2 - Russound CAV6.6 units running 12 zones from 6 sources
1 - Russound VM1-8 for HD video to 4 of the zones for now
* NOTE - I have a free CAT5e cable running to the zones where I want to control the TV power via IR signal.
MacOSR is offline
post #2 of 2 Old 06-19-2014, 04:23 PM - Thread Starter
Liked: 0
Here is some more information. Basically I want to do two things using the 12v trigger port on the zones from the Russound CAV6.6...
If 12v power goes from off to on send an IR command to the TV to power it on
If 12v power goes from on to off send an IR command to the TV to power it off
MacOSR is offline
Reply Home A/V Distribution
