Budget home av system - AVS Forum | Home Theater Discussions And Reviews
Old 07-04-2014, 03:18 AM - Thread Starter
Liked: 0
Question Budget home av system
Hey there guys hopefully someone can give me some more information.
I'm looking to fit a house av system into my house but there are so many different things I have no idea which and what to choose
Basically my setup will be, all the av equipment, 2x cable, bluray, music and video server of some sort (advice needed? Maybe pc?) all storedin the office and then in living room 2 bedrooms and outside I want to be able to play this equipment independently so a song playing outside while listening to a different on in bedroom, cable in lounge while watching bluray in the other bedroom etc... I want to be able to control these either through wall keypads and/or iOS and android devices
I have come across the control4 system I've heard of systemline for audio but not looked into this for the video side of things.
I don't want to spend thousands so cheapest possible solutions would be great but will be willing to look into spending more if it's worth it
mtwa is offline
Old 07-04-2014, 07:51 AM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
What country are you in.
Is this just video not audio. You talk two video zone and no audio zones but then talk playing audio outside. So how many audio and how many videos?
Based on the limited information above.
1 AVR with two zone HDMI output to take the cable, BD, music server.
Get the right one you can get surround sound to main zone and stereo to second.
Then sonos amps for the audio zones.
Sent from my LT26i using Tapatalk
SMHarman is offline
Old 07-05-2014, 04:02 AM - Thread Starter
Liked: 0
Thanks for your reply there will be video going to all the rooms the audio will be in so living room 2 bedrooms and and outside, will have speakers 5.1 ch in the wall and ceiling in the living room as well as wall mounted HDTV, stereo ceiling speakers for bedrooms which will also have HDTV on the wall, outside will be a pair of speakers and a projector.
mtwa is offline
Old 07-05-2014, 07:01 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
What you are looking at then is a 5 source 4 output HDMI matrix so likely a 6x6 one.
These are 1) cheap and unreliable. 2) expensive.
So budget is getting blown up with a distribution matrix.
Where do you live? Can you get TiVo? Do you have cable or fios?
EDIT. Actually you have an HT zone. Best to part that out subunits own avr and sources. Then a 4x4 matrix. Still pricy for the matrix though.
SMHarman is offline
Old 07-06-2014, 03:02 PM - Thread Starter
Liked: 0
live in the uk, we have cable virgin media Tivo my issue with a hdmi matrix is how do you control it, do you have to keep going into the office to change whats being viewed in each room or can this be done with an app on iphone/android or wall keypads?
mtwa is offline
Old 07-07-2014, 07:43 AM - Thread Starter
Liked: 0
Would it be possible to connect the two cable boxes I have to a computer and then stream that input to other computers,
I have 3 computers all running windows 8 pro I could use one to connect the cable boxes and bluray player to, using some kind of hdmi input card, then put the other two computers in the bedrooms but how would I then go about watching the inputs from the central computer on one of the other computers?
Would this be a cheaper option maybe?
mtwa is offline
Old 07-07-2014, 08:00 AM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
You control it by ir or ip or serial.
Each room would have some smart remote control you program so when you want a source it sends the command to the switch then sets the control for the avr audio and TiVo or whatever transport controls.
SMHarman is offline
