Buying New Sonos Connect:Amp vs. Used - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jautor
post #1 of 6 Old 07-13-2014, 07:50 PM - Thread Starter
kenchi's Avatar
Arrow Buying New Sonos Connect:Amp vs. Used
I'm planning on purchasing 3 to 5 Sonos Connect:amp units, and was looking at possibly saving some $ buy purchasing used ones from Ebay.
Does anyone know if there has been any recent hardware upgrades to the Connect:Amp devices (other than change the name from Zoneplayer 120, and the new box appearance) that I should be aware of buying used devices?
thanks
kenchi is online now
post #2 of 6 Old 07-14-2014, 02:05 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
According to Sonos, the ZP120 is the same as the Connect:Amp, just cosmetic differences:
http://forums.sonos.com/showthread.php?t=25880
SMHarman likes this.
jautor is online now
post #3 of 6 Old 07-14-2014, 02:14 PM - Thread Starter
kenchi's Avatar
Thanks! that is exactly the info I needed.
thx
post #4 of 6 Old 05-17-2015, 01:55 PM
aeromitch37's Avatar
Quoted: 20 Post(s)
Liked: 0
I'm in the same boat and looking at eBay to save $50-$75 per amp. A few sales look to be offering new in box devices. Did you end up purchasing from eBay and if so how was your luck? Thanks
aeromitch37 is offline
post #5 of 6 Old 05-17-2015, 03:07 PM - Thread Starter
kenchi's Avatar
Yes, I ended up buying 3 Connect Amps on Ebay. All "used", but did save up to $100 off the new price, and they work just as good as new.
So far no issues
Good luck
post #6 of 6 Old 05-17-2015, 08:37 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
I also got my zp80 off eBay. Works and good price.
SMHarman is offline
Reply Home A/V Distribution
connect:amp , ebay , Sonos
