Nuvo P3100 Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-15-2014, 07:47 AM - Thread Starter
Liked: 0
Hi All. Been reading up on this forum the past few days and wow... what a wealth of information and knowledge you all have. I am currently building a new house and want to do a whole home audio system. I believe the Nuvo P3100 is what I'm looking for but I had a couple of questions that I have been trying to find answers to and have been unsuccessful up to this point. I'm looking to accomplish 3 zones\ 3 sources right off the bat with upgrade capabilities 6 zones \ 6 sources and have complete control from my tablet and smartphone. We dont do a ton of streaming, but some... most of our music we have digitally saved to a computer. I understand the P3100 can play my digital library, but how will this computer be seen by the system? Is it a single source? My main worry is that if I'm listening to a file in zone 1, and my wife wants to listen to a file in zone 2, that she wont be able to because that computer is a single "source". Can I listen to 3 different songs in 3 different zones from the same digital library from a single computer? Also, was looking for speaker recommendations.. Definitely wanted to do in ceiling, something that sounds nice but doesnt break the budget, just a pair per zone, and all rooms are just normal sized. Thanks in advance!
haddixs80 is offline
post #2 of 7 Old 07-15-2014, 09:55 AM
jautor's Avatar
Quoted: 1309 Post(s)
Liked: 836
Each zone can access the library independently. It's just a file share being accessed by the device(s) - no problem playing three files in three different zones.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 7 Old 07-15-2014, 10:21 AM - Thread Starter
Liked: 0
Awesome, that is just what I was hoping to hear. Thanks for confirming, I really appreciate it. Any recommendations on a good set of in ceiling speakers to pair with the system? We were hoping to stay under 500 a pair. Thanks!
post #4 of 7 Old 07-15-2014, 10:33 AM
jautor's Avatar
Liked: 836
That's a very healthy budget for in-ceiling speakers! Many folks here have used the ultra-cheap Monoprice models, which I haven't heard personally, but they are of similar construction to speakers at much higher price points. I would avoid anything 'off-brand' bought at the big-box home improvement centers. Polk is a good low-cost choice, but I've been most pleased with either Boston Acoustics or Definitive Technology among my in-ceiling speaker purchases.
If you want to start cheap, go with a 6.5" speaker, as that cut-out size range will allow you to easily upgrade later to other 6.5" or 8" speakers. Starting with cheap 8" speakers might leave you with a big hole that you'll find limiting when it comes to swap out later.
Jeff
jautor is offline
post #5 of 7 Old 07-15-2014, 10:39 AM
trab37's Avatar
Quoted: 40 Post(s)
Liked: 27
I 2nd the Polk in-ceilings, I used the 70RT model in my house for audio only rooms and video with two channel audio areas and they sound great.
trab37 is offline
post #6 of 7 Old 07-15-2014, 10:51 AM - Thread Starter
Liked: 0
Great thanks, I really appreciate it. Yes, no doubt if I can get good speakers for less than that... I'm all about that! I had looked into definitive technologies and they look really nice, but I like that idea. I'll give something small and low cost a shot first and can always go up from there. I really appreciate the help. Please feel free to chime in any other advice you might have.
post #7 of 7 Old 07-16-2014, 05:51 AM
oktoberrust11's Avatar
Quoted: 71 Post(s)
Liked: 38
I'll just add that I've had good experience with Polk's in the past as well. However on my last few installs, I've gone with the Yamaha NS-IC600 speakers (link), and really like them. To me they have cleaner more crsip sound. Polk & Yamaha are very good budget friendly options; JBL, Klipsch, Def Tech are some good slightly pricier options.
Let us know how the P3100 install turns out!
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
Reply Home A/V Distribution
