Hdbaset 2.0 - any products support it? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By PaulKohler
post #1 of 16 Old 07-17-2014, 05:52 AM - Thread Starter
PaulKohler's Avatar
The 2.0 spec was announced a year ago but I cannot find any products that support it. I did stumble upon a chip maker that has built silicon that will support 2.0, but I don't see any product. I reached out to Altona and they only support 1.0.
I use Atlona currently, but need to expand and like the USB support in the 2.0 spec.
Does anyone have insight they can share?
PaulKohler is offline
post #2 of 16 Old 07-17-2014, 08:26 AM
jautor's Avatar
Quoted: 1210 Post(s)
Liked: 776
Well, that chip maker (Valens) *is* the HDBaseT hardware provider...
The CEDIA Expo in early September is the likely place for us to see actual product announcements.
Jeff
jautor is online now
post #3 of 16 Old 07-17-2014, 09:46 AM - Thread Starter
PaulKohler's Avatar
Looking for product that is shipping - will pay attention to this year's expo. Thanks for the info.
post #4 of 16 Old 07-18-2014, 10:46 PM
Joe Fernand's Avatar
Quoted: 267 Post(s)
Liked: 155
See - http://www.valens.com/newsroom/press...mcolligopr2014
A few months before you'll see products.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is offline
post #5 of 16 Old 07-19-2014, 07:27 PM - Thread Starter
PaulKohler's Avatar
Joe
Thanks joe for the reference - will keep an eye out - just thought I would see shipping product since it has been 1 full year.
I can wait a few months before I need to deploy additional extenders. The USB support makes the install I need much cleaner.
Paul
Joe Fernand likes this.
post #6 of 16 Old 07-30-2014, 03:32 PM
AmitP's Avatar
Liked: 0
I am looking to install a 8x8 HDBaseT (Lite) matrix based AV distribution solution - Wyrestorm or CYP or Octava. I have a 4/5 input sources and 10 rooms to cover (I will mirror into 2 rooms). I have about 5 months of flexibility in terms on when to make my purchase.
Does anyone have a sense of how HDBaseT 2.0 manufacturers will implement point to multipoint and will it reduce the price of switches?
AmitP is offline
post #7 of 16 Old 09-23-2014, 10:32 AM
Philip Klein's Avatar
Cedia 2014 Introductions?
Anything introduced at Cedia? Have been searching the accounts and have not found any mention of HDBaseT 2.0.
- Phil
Philip Klein is offline
post #8 of 16 Old 09-23-2014, 01:58 PM
jautor's Avatar
Liked: 776
- Phil
Didn't see any, and talking to the HDBaseT folks in their alliance booth, it sounds like will be "end of this year". Which probably really means January...
post #9 of 16 Old 10-13-2014, 05:47 PM
byronlobo's Avatar
I see Cypress have products on their website in europe. Certainly not cheap.
Look for HDBASET "5 play"
B
byronlobo is offline
post #10 of 16 Old 04-24-2015, 05:47 PM
AmitP's Avatar
Liked: 0
Anyone aware of a manufacturer close to launching a HDbaseT 2.0 product?
AmitP is offline
post #11 of 16 Old 04-27-2015, 08:51 AM
Quoted: 25 Post(s)
Liked: 2
I haven't seen any mention of it yet.
harveyAV is online now
post #12 of 16 Old 05-07-2015, 11:44 AM
Kramer Electronics
I believe Kramer Electronics has announced (in March) HDBaseT 2.0 products. I don't know if there are shipping or are shipping in the US.
post #13 of 16 Old 12-14-2015, 12:08 AM
Buttabean's Avatar
Liked: 29
http://www.bhphotovideo.com/bnh/cont...=REG&A=details
I found this while doing a search. Looks really nice spec wise.
Joe.T
Buttabean is offline
post #14 of 16 Old 12-14-2015, 11:44 AM
Quoted: 25 Post(s)
Liked: 2
That Atlona device isn't HDBaseT 2.0, however WyreStorm just came out with a 2.0 device.
http://www.wyrestorm.com/catalog/EX-100-4K-PRO
https://www.conferenceroomav.com/EX-100-4K-PRO/product
post #15 of 16 Old 08-02-2016, 09:01 AM
Blackbird™ 4k HDBaseT™
New product from Monoprice. Doesn't say HdBaseT 2.0 but speaks of HDCP 2.2, HDMI 2.0 and PoC. Intermediary between HdBase T 1 and 2?
- Phil
post #16 of 16 Old 08-02-2016, 10:39 AM
Quoted: 12 Post(s)
Liked: 1
HI,
KanexPro carries USB KVM extender EXT-HDBTKVM100 which supports HDBaseT 2.0 chipset. It supports 4k@60hz upto 100m and 1080 upto 150m.
This USB KVM extender is HDCP2.2 and HDMI2.0 with color depth of 10 bit.
Please check out the following link
http://www.kanexpro.com/item/?id=EXT-HDBTKVM100
send your queries to support@kanexpro.com
Thankyou
Jaspreet singh
jaspreet is offline
Reply Home A/V Distribution
