Nuvo led panel controlling multiple zones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-18-2014, 08:39 PM - Thread Starter
NotoriousBEN's Avatar
I have a grand concerto and two stereo amps that are controlling 8 zones in our house. Two of the zones are in the same room, a large living room with vaulted ceilings. There is only one cutout for a panel in that room. Is there a way to designate the panel to control both zones (all four speakers)? Perhaps to group the zones? I don't envision ever needing to control the zones independently so if they were permanently grouped that would be fine.
Is this what "dynamic zones" are for?
NotoriousBEN is offline
post #2 of 4 Old 07-18-2014, 08:52 PM - Thread Starter
I should also say that I can't get to the advanced zone control on my led pads. I see that there is a slave to zone option in the menu tree but it's greyed out on my pads
post #3 of 4 Old 07-18-2014, 11:19 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
See the manual page 27 - "Slave to Zone" will be the answer. A "group" is probably not what you want if you only have one keypad for both zones.
To access they greyed out menu (page 25) - highlight the option and hold down the OK button for 6 seconds...
Jeff
jautor is offline
post #4 of 4 Old 07-19-2014, 11:46 AM - Thread Starter
Jeff
perfect. holding down the OK button got me where i needed to go. thanks again, jautor
--b
Reply Home A/V Distribution
