No signal to tv's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-20-2014, 10:32 AM - Thread Starter
Liked: 0
No signal to tv's
ok-here goes. not an electronics genius; will try to explain my problem. my old fta box had an out to tv jack. my new one does not. my house is prewird with coax to tv's. how do i get signal to tv's. my new box has lnb out, usb, hdmi out, rca ports, rs, lan ports. it is a dreamlink t-5 if that would help. hope this is posted in correct forum and someone can help me. thanks
fivefivem is offline
post #2 of 8 Old 07-20-2014, 10:50 AM
FlyingDiver's Avatar
Quoted: 204 Post(s)
Liked: 58
You can use the HDMI port to connect to whichever TV is co-located with the box and get HD. For all the other TVs, you're going to need to use an RF modulator from the composite video and stereo output jacks, and you'll only get SD (which is all you got with your older box).
Something like this: http://www.amazon.com/Nyrius-NRFM100...dp/B005BCBK9W/
FlyingDiver is offline
post #3 of 8 Old 07-20-2014, 11:11 AM - Thread Starter
Liked: 0
thanks for reply-my main tv does not have hdmi port-older tv. any other options? cannot feed it with rca if i use them to feed modulator.
post #4 of 8 Old 07-20-2014, 11:20 AM
Quoted: 204 Post(s)
Liked: 58
Is it an HD TV? If not, just feed it with the output of the modulator like all the other TVs. If it is, then it'll have component inputs, which the receiver has. You'll just need to use splitter cables for the audio to feed both the TV and the modulator.
post #5 of 8 Old 07-20-2014, 11:24 AM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
Just note that this is an NTSC device. Since the OP mentioned "FTA", he may not be in the US or Canada... For non-HD sets, the OP may need the equivalent PAL device depending on the country.
Jeff
jautor is offline
post #6 of 8 Old 07-20-2014, 11:39 AM - Thread Starter
Liked: 0
Jeff
i am in the UNITED STATES. ok-so i need splitter rca cables to feed my primary tv and the modulator-correct? thanks
post #7 of 8 Old 07-20-2014, 11:42 AM
Quoted: 204 Post(s)
Liked: 58
Maybe. Is your primary TV HD? Does it have component inputs? If not, just use a coax splitter and feed it like you used to.
post #8 of 8 Old 07-20-2014, 12:40 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
Probably will work for the audio, possibly to probably not for video. Video jacks are terminated with a 75 Ohm resistor so connecting to two of them will cut the signal to each in half.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home A/V Distribution
