MCA-C5 or ACA-E5 SPHERE? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-21-2014, 05:43 PM - Thread Starter
bigo93bronco's Avatar
Quoted: 18 Post(s)
I need some advise about the sphere system. I purchased one awhile back for a steal, and then found out there is absolutely no way to configure yourself....ever. The reason I like the SPHERE is for the extra source inputs, and I like that you can use the composite video ports to distribute coaxial SPIDIF to any zone you want. I'm at the point where i'm almost ready to just bring someone out to program it for me, BUT I have a couple of important questions I need to answer first.
Is the ACA-E5 compatible with the touchpoint? Full metadata, coverart, etc?
Is the ACA-E5 compatible with the DMS? metadata and all of that available at keypads? through touchpoint too?
Should I just scrap the whole SPHERE idea? I really like that the MCA-C5 is fully configurable by the end user, but I really hate to give up those extra source inputs on the ACA-E5
If anyone knows anything at all about this stuff, PLEASE help me out (no one ever wants to talk about SPHERE stuff, lol) Or if you can recommend a SPHERE integrator in the DFW area that would be great too....
bigo93bronco is offline
post #2 of 4 Old 07-23-2014, 06:08 PM - Thread Starter
Quoted: 18 Post(s)
Is there anyone out there I could seek out that knows about the SPHERE stuff?
post #3 of 4 Old 07-25-2014, 11:48 AM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
The Russound Dealer locator Results page shows a list of dealers, denoting ones who are Sphere certified.
http://www.russound.com/dealerlocator.php
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 4 Old 08-02-2014, 05:33 AM - Thread Starter
Quoted: 18 Post(s)
Do you think any of them would be willing to come configure an ACA-E5 that I bought used (and tested as extensivly as I could) and installed myself? I'm not a CI, but I work in a similar field and would call myself and my work "professional". If i'm only having a CI program the ACA for me, would it be possible for them to do it remotly, or do they have to be on-site?
Reply Home A/V Distribution
