FIOS diplexer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-23-2014, 05:03 AM - Thread Starter
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
FIOS diplexer
I'm having issues with my FIOS setup. Sometimes the guide doesn't work. Caller ID isn't working. I get errors about not being able to connect to the network. I think the problem is I'm using a coaxial amp that goes up to 1002 and some of the Moca network is at a higher frequency. I read one solution is to use a set of diplexers to pass the higher frequencies around the amp.
I looked at these on amazon and they're cheap but they're designed for use with dish network, not sure if they'll work with FIOS.
http://www.amazon.com/Pack-Holland-D...words=diplexer
Does anyone have any diplexers they recommend?
KidHorn is offline
Reply Home A/V Distribution
