Connecting everything for home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-23-2014, 09:48 PM - Thread Starter
KyleJames13's Avatar
So my set up is as follow- onkyo ht-r390, vizio 60", Panasonic projector, xbox360 and time warner cable, logitech harmony 1100 to control everything.
The problem is I still have to unplug Xbox hdmi cable and plug in the component into back of Xbox for the projector. Same with cable box- have to unplug hdmi to get it in the projector. Obviously they do not have 2 video outputs but is there anyway around this? I have Xbox connected to av receiver via hdmi on game input also component sound from Xbox on VCR input, cable box is plugged directly into tv via hdmi but also have component sound going into av receiver in cable input.
Any ideas/ suggestions??
KyleJames13 is offline
post #2 of 3 Old 07-25-2014, 08:48 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
So you essentially need everything into your AVR, and two video outputs -- one to your PJ and one to your TV?
I don't have this setup, but I wouldn't see why you couldn't get everything in to your AVR and then some sort of HDMI splitter
Monprice has this one for cheap **I have no experience with it. They have others and other people have them too.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Should work, I would think
NickTheGreat is offline
post #3 of 3 Old 07-25-2014, 08:48 AM
Quoted: 386 Post(s)
Liked: 259
Or are you saying your projector has no HDMI input? Because then my solution will not work, obviously
Reply Home A/V Distribution
