Help! TV Above Fireplace...the rest in near basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-29-2014, 07:29 AM - Thread Starter
d_gmo's Avatar
I have mounted a TV above my fireplace. Due to the mantle, being small I would like to have my components in the basement right below. I have a Denon AVR591 Receiver, Verizon Fios Cable, and in celling speakers.
Would it work if I run a 30 foot HDMI Cable RedMere - Ultra Slim Series High Performance HDMI (http://www.monoprice.com/Product?c_i...seq=1&format=2) to the receiver in the basement from the mounted TV . I would also run in wall rated speaker wire from the in ceiling speakers to the basement receiver. Place the Fios Cable Box in the basement and hook it up to the receiver. Just wondering if you think this setup would work?? Thanks
d_gmo is offline
post #2 of 2 Old 07-29-2014, 09:10 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
It sounds like it could work in theory. How about remote control? You need to do something in that regard as well.
NickTheGreat is offline
Reply Home A/V Distribution
