Multiple zones: simple question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 08-01-2014, 06:46 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
So I've read so much that I think I've confused myself. Hopefully this is a simple question.
I'm going to have twelve zones in my new house, with three of those zones being 5.1 or 7.1 zones. If I plan to have the surround zones run by receivers, is there a way to use the zone 2/3 outputs of the receivers to run a few of the wha zones and have them all integrate seamlessly? The block I'm having in my head is how would I seamlessly control everything? Would it just be better to use the receivers for the surround then have separate amps also connected to the in-ceiling surrounds with the speaker selectors for when I want to listen to wha?
Examples:
1. master bedroom will be a 5.1 system. Would be easy to use the zone 2 for the master bathroom and the zone 3 for the master closet.
2. Keeping room will be a 5.1system. It would be nice to have the zone 2 power the back porch and the zone 3 to power the dining room.
branan1 is offline
post #2 of 20 Old 08-01-2014, 09:30 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
It's not. But don't worry, it never is...
"Integrate seamlessly" - not without a fully-integrated control system on top of all that gear (Crestron, Control4, Savant, etc.). Which I'm guessing based on the frugal nature of the question is probably way outside of the budget envelope...
Yes. And those speaker selectors can be automatic so you don't have to do anything "different" in those AVR-based zones. You can easily share the surround speakers with the WHA system, for example (assuming the surround channels are in-ceiling speakers which are typical placement for WHA usage).
For a 12-zone setup, you really want to have a consistent control scheme and sources, otherwise the whole thing will be confusing to operate.
Most important now, though, as it appears you're doing new construction, is to get all the wiring right. Do that and you'll have plenty of options.
Jeff
jautor is offline
post #3 of 20 Old 08-01-2014, 11:07 PM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
I believe I've got the wiring planned. Was my question frugal in nature? Probably cause I've been thinking about how i'm paying for all of the house "upgrades" and we're just now pouring the foundation lol.
Thanks for the help. I've already got a russound r850mc. I'll probably get a couple cheaper amps to run the rest of the zones and get the receivers for the surround rooms. Then use the automatic in-line selectors and add a few more sonos.
BTW, I've got your build thread bookmarked. Your theater is awesome! I'm planning mine now too.
branan1 is offline
post #4 of 20 Old 08-02-2014, 09:41 AM
jautor's Avatar
Liked: 777
Not explicitly, but experience tells me that when folks try to leverage the AVRs instead of buying a WHA, it's probably due to budget...
Ha! And we have a winner!
Well, if you home-run a few 14/4 speaker wires from those AVRs back to your central wiring location, you could certainly utilize the 'stranded' zone2/zone3 capabilities for some of those rooms. Unless you were already planning to centralize the AVRs - which would make that solution obvious...
Thanks! And if you read the early parts you'll see it wasn't started until a few years after I built the house - so I could recover from those "upgrades" during construction!
Jeff
jautor is offline
post #5 of 20 Old 08-07-2014, 09:22 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
Alright, more confusion.
If I want to control every room individually I obviously need some sort of controller. I was looking at the nuvo essentia 6 zone - 6 source. My thought was that I could get two of those and then just plug in a streamer or a couple more sonos. How's that plan? If I really only want two or three sonos, I still need the essentia style controller, correct? That's assuming I'm not going to do volume control pads in all of the rooms. I like the app based volume controls.
branan1 is offline
post #6 of 20 Old 08-07-2014, 09:47 AM
jautor's Avatar
Liked: 777
If you're not going to install keypads, you'd need the NuVo MusicPort server (MPS4) for mobile app control, as that's where the network connectivity / app support comes from. Otherwise you'll have no control of the system.
Without keypads / volume controls in the rooms, you'll want to go with a zone-player solution using either Sonos Connect:amp or NuVo P100/200/3100 zone players - and you'll need one per room, which will also give you all the flexibility you'd ever need...
Jeff
jautor is offline
post #7 of 20 Old 08-07-2014, 10:29 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
12 zones = two essentia with keypad / volume controls in all of the zones. Then however many sonos I want.
That would allow me to "turn on" the zone at the keypad and then control all of the sound with my sonos. Correct? "fingers crossed"
Is there a different route that you would recommend?
branan1 is offline
post #8 of 20 Old 08-07-2014, 01:44 PM
jautor's Avatar
Liked: 777
Yep. You'll control volume, on/off and switch between sources with the keypads. Then use the Sonos app for music browsing. And you can hook up multiple Sonos:Connect units and choose any combination of rooms to have music playing...
Using the NuVo MPS4 as the music server instead of the Sonos would get you a fully integrated solution, and you'd get metadata (title/artist/station) on the keypad displays. But that's considerably more expensive than one Sonos box - and something you can always upgrade to later...
jautor is offline
post #9 of 20 Old 08-07-2014, 02:47 PM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
Thanks for you help!
branan1 is offline
post #10 of 20 Old 11-05-2014, 06:06 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
So I ran three cat 6 and two rg6 to every TV location. Everything is home run to a closet. Question, what do I need to use to send the HDMI and ir to each TV location? Obviously I will need to be able to control a DirecTV box and receiver/amp from each TV viewing spot. I've looked at the monoprice HDMI/ir over cat 6 wall plates, but I'm not sure if that will work since I want to control multiple devices.
Any recommendations?
branan1 is offline
post #11 of 20 Old 11-05-2014, 06:51 AM
jautor's Avatar
Liked: 777
You can use several IR blasters from any one IR output port - so controlling multiple devices via IR is no problem. Avoid the 'unpowered' HDMI wallplates, and use extenders that require their own power supply for best results. As you've got ample cable, you can use the 2-cable extenders instead of springing for the HDBaseT versions - although those are generally the best...
Jeff
jautor is offline
post #12 of 20 Old 11-06-2014, 05:45 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
Thanks. I've gone down the rabbit hole and now it seems the best way would be to use a matrix. Do you think its necessary?
branan1 is offline
post #13 of 20 Old 11-06-2014, 06:34 AM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
How many sources do you need on how many screens.
Does the garage tv just need tv.
Also have you considered TiVo. Gets you DVR and many streaming sourced on one box. Often enough for secondary rooms.
SMHarman is offline
post #14 of 20 Old 11-06-2014, 07:38 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
I had TiVo, but it doesn't work with directv or uverse, so Im not going to use it in the new house. Our cable service is terrible! Really I could probably get by with just a 6x6, but I've never seen one of those.
branan1 is offline
post #15 of 20 Old 11-06-2014, 09:40 AM
jautor's Avatar
Liked: 777
You've leaped from remotely locating the equipment to the "need" for a matrix switch. If the only thing you're intending to provide access to is the set-top (sat/uverse/cable) box(es), you'll probably be better off without a matrix, and add enough of those receivers to cover your video zones.
jautor is offline
post #16 of 20 Old 11-06-2014, 09:45 AM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
Ok I got you. Can you run a splitter between the boxes to multiple displays? So come out of the cat6 "balun" and run into a switch that goes in a couple different locations?
branan1 is offline
post #17 of 20 Old 11-06-2014, 10:13 AM
jautor's Avatar
Liked: 777
You would split the HDMI signal coming out of a set-top box before it goes to the balun(s) - one balun set for each display run. Once converted to cat5e/cat6, it's a point-to-point solution.
jautor is offline
post #18 of 20 Old 01-07-2015, 12:11 PM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
Any recommendations on an 8x8 hdbaset matrix? Or maybe 2 4x4s?
branan1 is offline
post #19 of 20 Old 01-07-2015, 03:42 PM - Thread Starter
branan1's Avatar
Quoted: 26 Post(s)
I got to thinking. Rather than a matrix, I could go the cheap route at first and tie done rooms together. I've attached my chicken scratch. See if that will work if you don't mind.
branan1 is offline
post #20 of 20 Old 01-07-2015, 05:32 PM
SMHarman's Avatar
Quoted: 342 Post(s)
Liked: 108
Go bak to what Jeff said earlier.
Too many zones and too many control points and this becomes special occasion not every day.
SMHarman is offline
Reply Home A/V Distribution
