IR to 2 TV's using one source - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-06-2014, 05:55 PM - Thread Starter
Liked: 0
Hi
Just joined the forum and don't know if this is the proper section to post. If not Mod please move it to where it should be.
I have a DTV H25 receiver that has IR on the front of the receiver and a 3.5mm output on the back. You can only use one or the other and not both at the same time. I need to feed 2 TV's and am using 2 HDbaseT extenders that does HDMI and IR to both TV's. I am able to get audio/video to both TV's but need a solution to get IR to both TV's. What are my options?
dr3am is offline
post #2 of 11 Old 08-06-2014, 06:03 PM
smcmillan2's Avatar
Quoted: 379 Post(s)
Liked: 223
Originally Posted by dr3am View Post
Hi
Haven't used them myself, but many HDbaseT units include IR emitters to use at the "business" end to change channels on the cable/dish box. Does yours not include this? For example: http://www.monoprice.com/Product?c_i...seq=1&format=2 (the 2 additional cables in the pictures with the rectangular blocks on the ends)
EDIT: I'm assuming the DTV receiver is directly connected to one of the 2 TVs
smcmillan2 is offline
post #3 of 11 Old 08-06-2014, 06:17 PM - Thread Starter
Liked: 0
Yes they did include them. Only problem is that the IR on the front of the receiver is very small and I can not put both of them on the front of it. I have tried putting half of each one over the IR and no go.
dr3am is offline
post #4 of 11 Old 08-06-2014, 06:51 PM - Thread Starter
Liked: 0
No. The DTV receiver is in a hidden location away from both TV's. I am using a HDMI Splitter/Amp to feed the 2 extenders.
dr3am is offline
post #5 of 11 Old 08-06-2014, 07:31 PM
smcmillan2's Avatar
Quoted: 379 Post(s)
Liked: 223
...The DTV receiver is in a hidden location away from both TV's
OK, gotcha. Do you have the ability to hang the emitters out in front of the DTV receiver by a couple of inches? That should allow them to work, so long as they stay facing the front of the receiver.
What is the make/model of the HDbaseT units? You may be able to get smaller emitters that will allow 2 on the IR of the receiver.
post #6 of 11 Old 08-06-2014, 08:12 PM - Thread Starter
Liked: 0
I will give that a try. I can make a little bracket out of plexiglass.
I am using Zigen model Zig-HVX-70. They will only work with a certain brand receiver that was purchased separately. I have a box of all different kinds of cheap to expensive ones but had to call Zigen to get the correct one. They only supply the emitter for the end the TV is at not on the source side.
dr3am is offline
post #7 of 11 Old 08-06-2014, 09:07 PM
jautor's Avatar
Quoted: 1319 Post(s)
Liked: 844
Xantech dual-source "twin plug" IR emitter ($10):
http://www.xantech.com/Infrared/Infr...itters/282TPD/
Exactly for this type of application, and it works great...
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #8 of 11 Old 08-06-2014, 09:14 PM - Thread Starter
Liked: 0
Jeff
That is exactly what I was looking for. I will order one up and see if it works. Any first hand knowledge if it works with Zigen?
dr3am is offline
post #9 of 11 Old 08-07-2014, 06:10 AM
jautor's Avatar
Liked: 844
No, but it's a simple IR emitter, it would be hard for it not to work...
jautor is offline
post #10 of 11 Old 08-07-2014, 09:55 AM - Thread Starter
Liked: 0
I'll give it a shot. It's a 50/50 chance as these extenders are very picky about what emitters will work with them. Something about a low voltage emitter will work according to the engineer I spoke with at Zigen. I will update once I give it a try.
dr3am is offline
post #11 of 11 Old 09-17-2014, 06:32 PM - Thread Starter
Liked: 0
Jeff
Worked like a charm. Thanks for the help!!
dr3am is offline
Reply Home A/V Distribution
