HDMI Switch with CEC and Receiver, will it work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-07-2014, 06:43 PM - Thread Starter
javi404's Avatar
So here is what I am having trouble with. And I feel like I can't find another post somewhere online with the same issue.
I have a Toshiba 40 inch TV with 3 HDMI Ports (forgot model but its a few years old)
Port 1 is for Google Chromecast
Port 3 is for Onkyo HT-390 Receiver
The Onkyo HT-390 has 4 HDMI inputs and 1 output (port 3 on TV)
Onkyo HT-390 has following devices currently:
Sony PS3
Sony Blu-Ray (yeah i know the PS3 can do blu-ray)
Roku 2
Verizon FIOS DVR
This leaves me with just 1 port open.
Right now it seems all would be well because the newest addition to my setup is a RaspberryPI running XBMC. (RaspBMC)
So big deal, I have one HDMI port left on my TV.
The TV remote can control the XBMC, Sony Blu-Ray, etc. (using CEC)
The TV remote can switch the inputs on the Onkyo HT-390 (using CEC of course)
Here is where my problem lies.
My TV doesn't support ARC (its a few years old), I have a TosLink cable from the TV to the receiver.
So if I'm watching youtube on my Chromcast or Even broadcast TV with 5.1 audio, I get surround sound just fine. But my TV will not pass any 5.1 format via the TosLink cable if the source is an HDMI port (tested with multiple devices and researched this before)
So, with XBMC on port 2 of my TV, I have to downmix content to 2 channel or else the Onkyo won't get all of the channels.
My Too Long Didn't Read question:
Are their any HDMI switches that support CEC?
I want all devices to be plugged into my receiver (do to the limitation of my TV) but still want the ability to control and switch to the devices using my TV remote via CEC technology.
I tried one switch off of amazon but it seems to block the CEC communication even on the active device so with a XBMC attached, I have to plug in a keyboard or a wireless mouse to control XBMC.
Has anyone else run into this strange combination of issues?
I really don't want to have to upgrade my receiver/TV or both right this second, but next time I do, I will make sure I have 15 HDMI ports.
Attached pic related: using TV remote to select input source on Onkyo Receiver.
javi404 is offline
post #2 of 8 Old 08-07-2014, 10:00 PM - Thread Starter
javi404's Avatar
Update:
After doing a-lot of Google-fu since my original post, it seems there are HDMI Switches out there that support CEC. I think this is exactly what I need. I just can't seem to find a good one anywhere.
javi404 is offline
post #3 of 8 Old 08-15-2014, 07:22 AM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
Originally Posted by javi404 View Post
Update:
As you toil away at this, let the rest of us know which ones to consider/avoid. I too am looking for some HDMI switching options involving a chromecast and I'd like to avoid having to experiment too much.
wkearney99 is offline
post #4 of 8 Old 08-30-2014, 02:12 PM - Thread Starter
javi404's Avatar
Hey, sorry just saw this reply now.
I went with a monoprice model. It will pass CEC but it won't autoswitch the way I want it to. I'm probably just going to move some devices around.
Right now when you turn on the TV, it turns on my onkyo as expected, but then the onkyo turns on and switches to the HDMI switch. The hdmi switch then switches to the my XBMC (raspbmc) device.
I haven't analyzed the traffic on the CEC channel to see what is going on but i will and post it here.
The model I have is: HD411-E3
I'm happy to report that:
XBMC <--> Monoprice HD411-E3 <--> Onkyo <--> Toshiba TV
: allows the Toshiba remote to control my XBMC raspberri pi setup.
If there are any questions please ping me. I've been hacking at the CEC tools on the XBMC box.
javi404 is offline
post #5 of 8 Old 08-30-2014, 06:06 PM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
How is not doing what you want?
And this isn't ideal? When you power up the Onkyo is it just defaulting to the HD411 switch? Is the AVR then causing the switch to power up? When it comes on, is the switch also just defaulting to the input that has the RasPi connected?
If you start 'casting to the Chromecast, does the HD411 get switched automatically?
I suppose the next interesting question is whether or not you can send instructions to the TV that would make it all the way through to the HD411 switch and be able to change it's inputs. Is that possible? That'd be a neat trick...
post #6 of 8 Old 10-08-2014, 01:14 AM - Thread Starter
javi404's Avatar
So I haven't tried to control the switch directly via CEC from the pi, but when the TV turns on, sometimes the PI switches the monoprice switch and the receiver so that the XBMC / PI is the device displayed when you turn the TV on. If I stream a chrome cast video it will switch the monoprice device so that it is the displayed device but that doesn't channel up stream to the onkyo. Overall I'm happy. I just need to see what I can do so the XBMC / PI doesn't takeover every single time the TV gets turned on. I rather the last source be displayed. I'll post more details here once I have more time to play around with it all.
javi404 is offline
post #7 of 8 Old 12-04-2014, 09:32 AM
akpak's Avatar
How are you getting 5.1 from your Chromecast considering Chromecast is connected to an HDMI port and your TV won't pass 5.1 through Toslink if source is HDMI?
Etiher way, I know you said you researched this but it seems odd that your TV won't pass 5.1 if source is HDMI. I think more than likely, it's due to the settings on the source- i.e. if it senses a stereo TV as the output, it will only pass stereo (not 5.1) unless you manually set it to pass 5.1 over HDMI. I could be wrong about your particular case though where it's just a quirk with your particular TV.
Found this thread while searching for reviews on HDMI switches. I'm curious how your monoprice model has held up. Couple of reviews seemed to suggest that it worked great until it failed after weeks/months.
akpak is offline
post #8 of 8 Old 12-05-2014, 07:22 PM - Thread Starter
javi404's Avatar
So I cant get 5.1 from the chromecast on the TV HDMI port. I ended up buying an HDMI switch that has CEC. Even with TOS link TV won't pass 5.1 from its input sources to the receiver. I found the more I researched that this was a common problem and I think someone posted something about sound bars having the same issue. TV not relaying 5.1 audio to the sound bar. My monoprice model has held up so far. No real issues with it. Its a semi dumb device but it passes CEC data and that is all that matters to me. I now have no HDMI devices plugged into the TV except the receiver for video because of the 5.1 pass-through issue. TV that support audio return channel (ARC) might be the solution to this problem.
javi404 is offline
Reply Home A/V Distribution
hdmi switch cec receiver tv
