Testing for Continuity for wire to outdoors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-20-2014, 05:08 PM - Thread Starter
TheNit's Avatar
I've looked at many YouTube videos on how to test for continuity of a speaker wire or other wires using a voltmeter but they all conveniently have the wire ends within 3 inches of each other. I had my house pre-wired with speaker cables to go from my stereo cabinet to an outdoor box and am now trying to set it up. One cable works and the other doesn't. I want to ensure that there is a break in the cable but I'm not sure how to do it. The cable has 3 conductors (black/white/grey) and I'm using the Band W. How do you use a voltmeter to check if these conductors are intact and it's not connections? Do you use the ohms setting and twist 2 conductors together and test them at the other end? Is there a way to just attach the voltmeter at the end of one conductor and do something at the other end to indicate that the wire is not broken? I'm sure this pretty basic but I've been search the web for a couple of hours and have found little.
TheNit is offline
post #2 of 2 Old 08-20-2014, 06:20 PM
jautor's Avatar
Quoted: 1303 Post(s)
Liked: 835
Yes. If you get a reading of 0 ohms, you've got continuity. But you could also have a short between the two wires, so test the wires before you twist one end together - you should see 'infinite' ohms.
Attach a 9V battery to one end and you can test for 9V at the other end.
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
Reply Home A/V Distribution
