Where to buy bulk panel mount 75 ohm bnc connectors (female)? - AVS Forum
Old 11-11-2014, 12:45 PM - Thread Starter
FusionITR's Avatar
Can someone suggest a distributor where I can buy 75 ohm panel mount bnc connectors in bulk? I mean 50+?
Also, at a reasonable price per connector, maybe around $1 per connector.
FusionITR is offline
Old 11-11-2014, 01:09 PM
olyteddy's Avatar
Quoted: 175 Post(s)
Liked: 259
Why would you want to use a BNC connector and then specify 'cheap'???
olyteddy is offline
Old 11-11-2014, 01:22 PM - Thread Starter
FusionITR's Avatar
Maybe I should of said "reasonable price" instead?
Old 11-12-2014, 10:03 AM - Thread Starter
FusionITR's Avatar
Nothing?
Old 11-12-2014, 10:13 AM
oktoberrust11's Avatar
Quoted: 13 Post(s)
Liked: 24
Originally Posted by FusionITR View Post
Nothing?
eBay?
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
Old 11-12-2014, 11:30 AM
Skytrooper's Avatar
Quoted: 57 Post(s)
Liked: 86
Haven't priced them in a while but I used to get them from Newark Electronics.
(LCD - Sony KDL - XBR4) (Receiver - Sony STR-DA4ES)(Blu Ray - Oppo BDP-83) (PS3)( Dish Hopper DVR With Sling) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
Old 11-12-2014, 07:31 PM
olyteddy's Avatar
Quoted: 175 Post(s)
Liked: 259
Are you looking for feedthrough or solder/crimp? There are lots of vendors of either but as I said BNC is not inexpensive. Newark, Mouser and DigiKey are three that come to mind. Then there's always Amazon...
olyteddy is offline
Old 11-13-2014, 03:19 PM
AV_Integrated's Avatar
Quoted: 334 Post(s)
Liked: 376
Is this for HD-SDI or something? We still use some BNC stuff, but the digital switch has almost completely destroyed our use for them as a company.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
