Video dist over Cat6 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-01-2015, 06:37 PM - Thread Starter
BPU
Liked: 0
Hi,
Long time reader and have learned a lot from everyone thus far. Thank you. I have been having a really tough time figuring out the optimal low cost solution for my home, however, and was wondering if you might help.
Situation:
3 TVs today, all three within 120 feet of utility room (all 3 smart Samsungs)
All TVs have Cat6 wiring (2 each)
All equipment in utility room:
  • Silicon Dust HDPrime
  • a PC running Windows 7 media center
  • A bluray player
  • 24 port patch panel
  • GB switch
I will be adding another floor to the house in the next 1-2 years and will be adding another 3-4 TVs. Also, additional video sources may get added to the utility room later, but trying to keep it simple for now
My top two requirements are no boxes (cable box or Xbox) under the respective TVs and a same/somewhat similar user interface/remote for each of the TVs (wife and young kids).
Questions
1. I like the concept of a 4x4 HDBaset matrix but am not enamored with the cost of a (non-Monoprice) unit. Particularly with 4k on the horizon. Is there a setup or solution that meets the requirements above that is not HDBaseT that you would recommend?
2. Will I need extenders from Ceton or whomever irregardless of whether or not I choose HDBaseT protocol? If so, where do they reside?
3. What remote control system would you recommend if I went with HDMI over Catx or some other non HDBaseT system?
Thanks again - I could get professional help but I get satisfaction from DIY projects - even if I get a bit over my head at times and have to ask strangers to point me in the right direction!
BPU is offline
post #2 of 5 Old 07-01-2015, 08:12 PM
ruckus87's Avatar
Newbie here with a young family and in the process of building a very similar setup in my new home.
I was thinking of using a HDbaseT Matrix with a Loxone control system to manage all of the equipment at the head end, but would love to hear your thoughts on this.
ruckus87 is offline
post #3 of 5 Old 07-02-2015, 06:21 AM
strohj's Avatar
control4 has a UHD capable matrix available
strohj is online now
post #4 of 5 Old Today, 05:34 AM - Thread Starter
BPU
Liked: 0
I may not have done a good job with my summary, or perhaps there is a dumb question in there somewhere. Was wondering what some of the more knowledgeable posters might buy if they were in my situation. Happy Fourth everyone!
BPU is offline
post #5 of 5 Old Today, 10:42 AM
jautor's Avatar
Quoted: 609 Post(s)
Liked: 497
Remotely locating game consoles can be difficult - the controllers have to reach, and you have to travel to the unit to switch disc-based games. Same true for blu-ray players - in primary AV viewing areas, you probably want a nearby spot for 'local' sources.
No.
But with two category cables to each display, you can find some less-expensive 2-cable solutions. Make sure you get one with IR repeating/routing to handle control regardless... Also note if you consume both category cables for video, you don't have anything left for wired Ethernet.
At both ends. But if you're really going down the matrix path, get an integrated unit with the extenders (HDBaseT or otehrwise) built-in.
See above - get an integrated unit with IR routing...
Jeff
jautor is online now
Reply Home A/V Distribution
