Multiple (>2) Ground Block - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2003, 01:41 PM - Thread Starter
jdsolomon's Avatar
Anyone know of a ground block with more than two (pairs) of F-type connectors? I've got at least 5 RG-6's coming into the house that I'd like to ground, and would prefer one big block to three (two duals and a single). Or do you folks not think that ground blocks are even necessary?
Jim S.
jdsolomon is offline
post #2 of 3 Old 01-17-2003, 08:09 PM
gsjmia's Avatar
Can't imagine why you would have five RG-6's coming in, but if the three are properly bonded to the ground wire it shouldn't make any dif in the ground. Ground blocks are cheap--about $1.75 each.
One big one would look neater, but if you mounted them in a straight line it could be made to look neat. I always like to stub up a piece of 1/2 inch conduit and mount the ground block inside a weather proof plastic receptacle box to protect it from being hit by weed eater, etc.
In my opinion, you can never have enough grounding, and if these are the cable entry/demarcation points, I am pretty sure code requires them.
gsjmia is offline
post #3 of 3 Old 01-18-2003, 10:22 AM - Thread Starter
jdsolomon's Avatar
To answer your question:
oval dish w/ 2 x dual lnb + sat c kit + ota antenna = 5 RG-6
all of which connect to a Spaun 5x16 multiswitch which is indoors.
Closed Thread Home A/V Distribution
